The 1,000,000 Box Blade post!
   / The 1,000,000 Box Blade post! #1
DrewL
Sandwich, MA
Kioti
For such a simple implement (not that I would have designed it), it is amazing the results it provides. For what these things cost ($600 5') vs the work they do is tough to beat. Pound for pound one of the better buys IMO. /forums/images/graemlins/wink.gif
   / The 1,000,000 Box Blade post! #3
Hi there
If you had access to a Bobcat skid loader would you have need for a box blade? Never used a box blade. Does it do anything special?
Cheers
   / The 1,000,000 Box Blade post! #4
Hi there
Cheers
   / The 1,000,000 Box Blade post! #5
I think a box blade would still be a great option. A skid steer is often too rough on the terrain just in its method of turning.
A box blade is a very versatile implement. Rippers/scarifiers allow ground to be ripped apart and dirt collected to move to another location, rippers can be used without dragging the dirt, pusing backward, using the rear outside blade can easily fill depressions and push large piles of material.
I've used a skid steer, and the wheels often leave a lot of damage that doesn't happen with a tractor and box blade.
John
   / The 1,000,000 Box Blade post! #6
John
KiotiJohn is correct about the potential damage skid-steers can do. Hense the name, SKID-steer. Skid-steers are a versitle machine but the way they turn can be a drawback although on a dirt road that is almost a non-issue. Most anything with a loader can acomplish what a BB can do but with several additional passes. In my case, a single pass on a dense grade bluestone road took care of all of the potholes...........some as deep as 10". Quite impressive
   / The 1,000,000 Box Blade post! #9
My neighbor who was building a new home 2 yrs ago used a 5' box blade and a Ford 8N tractor to do all of his backfilling around his basement and dig out a 300' driveway. With his low HP tractor he was able to break loose and move many tons of dirt. This big project was the first time that he'd ever used one and now he swears that a box blade is one of the best implements ever.
I think that some times they can be difficult to adjust properly or control but they are useful and do have their place.
   / The 1,000,000 Box Blade post! #10
John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
John Deere Gator...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
Skidloader Forks (A50774)
Skidloader Forks...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
