the 191.00 tooth bar
   / the 191.00 tooth bar #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
yesterday i went to repair a gravel driveway for a friend and could not hardly penitrate the gravel due to the ice which had not melted yet. Here in Tulsa we got about 4-6 inches of sleet over a 3 day period and even though the temps have been up around 50 it still has not melted away in the wooded areas. Last night I spent hours looking up different tooth bars and decided to build my own. I am about 2 miles from my Kubota dealer and since i needed new teeth for my backhoe I looked into what they had to build my own bar. they only had one shank and I wanted five so I spent the next 3 hours driving to every tractor and equipment dealer in the area to try and find what I was looking for, the second place I went told me about H & L tooth company which was on the other side of town from where I was. To make this long day short i ended up there around noon after going to all the other tractor shops and was able to buy 5 shanks, 5 teeth, and 5 pins for $191.00 bucks. I allready had a worn out grader blade to make my piece for the shanks to weld to. Looking around the net I noticed the beveled steel plate the more expensive teeth bars were using, i suspect that they are using a new piece of stock just like the one i was using that was old and worn down. You can find these plates at John Deere industrial equipment dealers, the bolt down to the front "scraper edge" of a large loader. I cut mine down to a very tight fit inside my bucket, tight enough I had to grind on it to get it to fit, I did this to maximise strength. My thoughts are "if it moves it will bend or break". I welded all my shanks in place and welded the bolt on portion with 1/2 inch steel plates that measure 3"x3". since i only own a 110 volt mig i welded each weld then ground it down and made a second pass. Throuh a coat of primer on and came out a couple hours later to test it out. My back yard is a hill side that is full of sandstone, I wasnt at it 5 minutes and was absolutly amazed at how it would rip the rocks out of the ground and leave the dirt and I was still able to "back pull" and level. If you own a small tractor and work it in any kind of rock you have to buy or build one of these. its amazing !!!!!!!!!!.
   / the 191.00 tooth bar #3
Well, when you need one you need one. I paid less that half that for ones I ordered, but had to wait on the delivery... Agree the toothbar is the cats meow. I can outdig my neighbors 70 hp tractor which outweighs me probably 4:1. he borrows mine for digging, but we keep it even. Enjoy, you are still ahead of buying one and had the fun of DIY!
   / the 191.00 tooth bar #4
Where did you order yours from?
(can you e-mail me with price and part #'s?)
jb
Yahoo! Photos - workinallthetime's Photos - kubota bx23 2005 model
i think that will work i duno, new to this site.
also note that the teeth i bought are the ones with replaceable teeth. I bought 5 shanks, 5 teeth, and 5 pins. though this might not be the cheepest route to take i felt it was the best considering i can replace teeth should i need to due to wear. i found some like the ones i bought for 55.00 each on the net i also found some at the dealer that were half the size of mine and were the same cost, also i founf the ones which have non replaceable teeth on the net for anywhere from 15.00 each to 50.00 each. with all this in mind the ones i bought are twice the size and strengh of anything i found. since i just ordered a set of replacement teeth for my backhoe this was a factor in the choice of teeth i made. concrete is **** on bucket teeth
   / the 191.00 tooth bar #6
I got mine ( with replaceable teeth) from Fabco. I think the shanks were about $9 ea, the teeth about $5? and pins about $1 ea. I pulled down their catalog page off the web, they have a number of different 2A shanks, blew them up on the copier until they were the dimensions shown on that sheet, then cut out the paper and tried them on my bucket and got the one that fit best. Then I had a friend bevel a piece of 5/8 by 3 steel and welded them on I don't have the number I used and yours may be different anyway, but I think I used the TB-8000-2A ??? They were pleasant to deal with! Fabco Inc. - Castings - Fabrications - Forgings - Digging Teeth - Findlay, OH
good luck!
   / the 191.00 tooth bar #7
That is what I did as well. I just bolted the teeth straight on to the bucket - the bottom is hardened steel and has worked just great with no extra re-inforcement. Cheap, quick, and easy. The holes don't cause any problems with the teeth off, either.
   / the 191.00 tooth bar #8
Hi All
Just finished up with my tooth bar on JD790.
Picked up six ,series 23 adapters, teeth and pins at John Deere Ind Dealer.
Paid $ 161.00
I do not think I will ever wear these out.
First job is going to be pulling up about 40 feet of overgrown forcythia bushes. Told the Mrs. Could not do the job without the Tooth Bar. I have found that a new peice of equipment is easier obtained if you link it to one of your wife's projects.
Ray
   / the 191.00 tooth bar #9
good luck!
Thanks!
The catalog is a great start!
jb
