The gully to pond project
   / The gully to pond project #151
jinman;2725542 I pretty much danced a jig on the dam because all this work has been leading up to this moment (1st picture).QUOTE said:
Jim,
I couldn't resist making the little animation attached when you said you danced a jig. It plays fine locally on my IE-9 browser and depending on what TBN does to the code it should work if you open it full in your browser.
It should work on Firefox and Chrome although the colors may shift a bit.
I doubt if it will work on a MAC.
Will be a good test of what TBN does to images..
Ron
   / The gully to pond project #152
Jim,
Ron
It works on my Firefox :thumbsup: ... but that's not dancing on the dam!! :laughing: :D
That's one cool bird! My gig looked more like the chicken dance without an accordion accompaniment.:D
Works in Chrome just fine. . .
   / The gully to pond project #155
Gonna have a lot of Water for your Garden :D:thumbsup:
   / The gully to pond project #156
How did you do the sand/clay mix? I have about 250 yd of sand I took out of a sandbar at the mouth of a creek and have been thinking of mixing that with the clay. I'd put down a layer of each and then run over that repleatedly with my 6' wide KKII tiller. I'm thinking the clay would have to be pretty dry, but that should work for mixing. What do you think?
That be easier then what I did one scoop(mini ex) at a time, plus I tried to lay it in thin layers. Yes I did wait for it to dry much easier to work with.
I think the professional guys use big drum mixers, but those are not in my budget. All my money is going to culverts and rip-rap.:confused2:
   / The gully to pond project #158
Jim,
I don't know where you are buying culverts, but for the last 5 years, I have been buying black double wall culverts from Contech Construction Products. Yesterday I picked up 60 feet of 8 inch culverts for $3.17 a foot. Local guy wanted over $10 a foot. A few years ago, I was pricing 24 inch culverts and found them as cheapest. They are still the best priced.
hugs, Brandi
Brandi, TSC has 15" dia. x 20' long plastic culverts for $199 each. I don't know that one culvert would be enough in a heavy rain, but don't want to go to 24 because the culvert would need to be buried 11" deeper. I'm thinking two 15" culverts side-by-side with 18" of clay between them for a good seal. That will give me the flow I need and allow plenty of freeboard up to the dam level. One of my problems is that I sold my 18' utility trailer and only have my 12' dump trailer. I'll probably have to have the culverts delivered. I'm going to check with a couple of local lumber yards too. If I can buy local for nearly the price of TSC and give a local business my money, I'll do that, even if it's a few more dollars. One little lumber yard offers free delivery.:thumbsup:
   / The gully to pond project #160
Jim,
<sigh> Conroe TSC does not carry culverts. Our Lowes did, but do not now. That is where I bought my 15 inch culverts for the pond's overflow under the driveway. Contech Construction Products has a plant or yard here.........
Arlington Plant
2020 W Division St
Arlington, TX 76012
Phone: 817-265-2255
Fax: 817-265-2250
Houston Yard
12040 Tomball Pkwy.
Houston, TX 77086
Phone: 281-272-5655
Fax: 281-272-5653
Schulenburg Plant
232 Oakland Rd.
Schulenburg, TX 78956
Phone: 979-743-4123
Fax: 979-743-3120
Seymour Plant
1100 N. Main St.
Seymour, TX 76380
Phone: 940-888-3871
Fax: 940-888-5333
Sulpher Springs Plant
1009 S. Como St.
Sulpher Springs, TX 75483
Phone: 903-885-0673
Fax: 903-885-6978
Taylor Plant
220 Gym St.
Taylor, TX 76574
Phone: 512-352-8592
Fax: 512-352-2587
It might be worth your $$$ to check them out. I do know they deliver also, at least from the Houston yard.
hugs, Brandi
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
UNUSED GRASSROOTS IMPLEMENT 5' BOX BLADE (A57192)
UNUSED GRASSROOTS...
TRUCK BED TOOLBOX (A57192)
TRUCK BED TOOLBOX...
Deere 35P (A53317)
Deere 35P (A53317)
Hercules Gun Safe (A55853)
Hercules Gun Safe...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
