the perfect gravel driveway
   / the perfect gravel driveway #11
Thanks.
We haven't put the smaller stone on the drive yet. What you see is the 3" crusher run. I'm not sure exactly how deep the rock base is. Nobody ruts it including Semi's. I'd take a guess its about 10-12".
When we put the 1 1/2" down it will be about 5" maybe 6" thick.
   / the perfect gravel driveway #12
If you have a pretty good, hard driveway to start with, and you are just looking to widen and de-weed it, I would start by "scratching" up the gravel with the ripper teeth on the boxblade set to about 3" below grade, and angle the box so that it is very slightly angled back. That is, the front cutting blade should be only slightly higher than the back cutting blade.
This should scrape up a fair bit of the existing gravel, and the box will carry it along and spread it out pretty smoothly once the box fills up. After a few passes this way, you will get a feel for how much of the driveway is gravel and how much is dirt. If you get very little gravel, you should buy a few loads, depending on your length, width and how deep you want it spread.
The resurfacing work could be very major, including lots of additional gravel, or it could be very minor, requiring only to scrape it loose and re-spread it. It really depends on what is on top already and what the top layer is supported by - earth or crushed rock.
Anyway, the best way to learn this stuff is to get out there and do it. Just give it a try, and don't try to go too deep in any one pass. That way, if you make any mistakes, they are easy to correct. Once you have spent some seat time with the box blade, you may find that a landscape rake works well in conjunction with the box blade to "finish off" the surface.
Good luck and have fun /forums/images/graemlins/smile.gif
thanks for the info everyone. i'll give it a shot.
paul
   / the perfect gravel driveway #14
Paul,
I like to use ABC gravel. It has a mixture of fines and rock that
locks togather like concrete.
For the grass on the gravel I would just leave it alone. Its going
to grow back anyway. My 900 feet of road is covered in grass
since it gets very little traffic. My driveway started growning
grass this year as well....
I have learned that if you want to grow grass put down gravel.
All this nonsense about fertilizing the grass, plugging the soil,
dethatching, etc, is for the the birds. Put down gravel and
grass will grow. :cool:
You can put down geotextile fabric. This is to keep the gravel
from being pushed into the dirt. If your gravel is staying on
top of the soil you might want to forget about the fabric. If
you want to use the frabric it will make your life much easier if
it is put down on a flat surface. In this case you want to mow
or remove as much of the grass as possible if you put the
fabric on top of the existing gravel. Of course if you do this
you have to buy more grave to put on top of the fabric which
costs more dollars... You could scrape off much of the gravel
and grass to get a level surface, put down the fabric, and
then push the gravel back on the fabric.
The fabric I bought was 12.5 feet wide and on a 360 foot lond
rool. It was about $300 for the roll. The fabric is used to
stabilize the roadbed so that you don't have to bring in lots
of rock to build up the driveway/road.
I put the fabric down on my driveway. So far its holding up
reall well. I don't put alot of traffic on it yet but it held up the
50,000#+ dump trucks without a problem. No rutting. Time and
the house construction will be a better test....
Later,
Dan McCarty
   / the perfect gravel driveway #15
</font><font color="blue" class="small">( My 900 feet of road is covered in grass since it gets very little traffic. My driveway started growning grass this year as well...)</font>
Dan,
I have a 500' road, and used rough sand instead of gravel. I sewed bermuda turf on it, and it's beautiful and rides very smooth. Traffic and hot weather kills other grasses and weeds, and the bermudagrass thrives. Rain is no problem. Neither are cement trucks or dumps. No need to fertilize, but I do just to make it greener. Everyone loves my road, and lots of people stop to ask me about it.
   / the perfect gravel driveway #16
Lets see some pics. /forums/images/graemlins/smile.gif
   / the perfect gravel driveway #17
Well, the timing is bad because the grass goes dormant from Nov-Mar. So it will look off-color. But I'll dust off the camera and shoot a couple of pics. /forums/images/graemlins/smile.gif
   / the perfect gravel driveway #18
Sometimes stuff dieing off or going dormant this is a good thing. I can finally see where I left all those log piles sitting in the trees /forums/images/graemlins/grin.gif
   / the perfect gravel driveway #19
have_blue,
My road is pretty as well. Once we move out there I'm sure we
will have two gravel tracks that will be grass free but I like the
looks of it. The driveway looks icky because the grass is only
clumped up and not covering the gravel. Once the house
building is finished I'm going to put down a few more loads of
ABC and finish the drive. If the grass takes over its ok with me!
Course it is one more thing to mow! :cool:
Later,
Dan
   / the perfect gravel driveway #20
</font><font color="blue" class="small">( My road is pretty as well...ourse it is one more thing to mow! :cool: )</font>
Dan,
Yea, mowing is not my favorite thing. It makes me think too much /forums/images/graemlins/crazy.gif
I live over 5 miles from my land, and don't drive on my grass road every day. If I did, I guess it wouldn't be nearly as pretty.
I'm working on a bike trail around the premiter of my property. It already looks nice, but I have to add sand and get some better grass growing and it will look great.
I bet all that stuff looks unusual from the air. Time for another arial picture.
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2024 BRAZOS 53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
New Holland B95 Backhoe (A50490)
New Holland B95...
