JDgreen227
Super Member
The repairs are going to be different than steel. With Aluminum you're not going to just pound out a dent. What this means is small dents could cost more to repair than on steel. Larger dents that require the panel to be replaced probably will not cost much different. I personally believe that Ford is eating the extra cost of the aluminum panels to keep costs as comparable to steel as possible. Things that are going to cost a lot more will be structural panels. Things like the support for the fenders, door pillars, etc. They would just be pulled straight if made from steel. With Aluminum they will need to be replaced which will require a lot of work to remove everything attached to and around the panel to be removed. Don't forget the whole panel will most likely need to be replaced. Rolling an aluminum cabbed truck on it's side could mean the whole cab needs to be replaced. I would say the jury is out for at least a year or so. By then insurers will know the real cost of aluminum on a large scale.
Excellent post and well thought out...!!!! :thumbsup: And BTW as I have been following this thread I have wondered: Are the materials needed to fill dents on aluminum body panels any different from those required on steel body panels?
