The strange case of the hot 755 compact tractor
   / The strange case of the hot 755 compact tractor #11
Dr Bill,
Thanks for the post...I have an JD 850 doing the same thing! I will try some of the posted tips before rebuilding....p.s. not a boring thread if you have that problem! Cheers
Hi McFarm,, and welcome... I think your 80 series yanmar is a lot tougher than the 72 series I have.. At least from my prior reading over the years...
I think the idea of checking for bubbles in the radiator while it's running but still cold is a good idea.. I have read of those engines having a bad head gasket and also some reports of cracked heads..
Also, I removed my thermostat when I first started testing... I didn't think it was the problem,,, I just wanted it out of the way so I could check flow and bubbles and such without worrying about what the thermostat was doing or being in the way..
I hope you have good luck finding your problem ,, and please keep us posted....
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
White Metal Roof Panels (A55758)
White Metal Roof...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
