There must be a better way
   / There must be a better way #31
</font><font color="blue" class="small">( You guys may think it's stupid but we're not the ones hunting for our septic tanks. )</font> Ouch. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
-Mike Z. /forums/images/graemlins/grin.gif
   / There must be a better way #32
lbrown,
Sounds like you're comparing your system to a different type of setup. Telling them to be smart and not bury there cover again because your brothers tank is that way isn't very helpful, and is quite rude.
His cover is buried in the ground by design. Leaving it uncovered creates all sorts of hazards and may lead to future issues by contaminates entering his tank as well.
You ignored these questions I asked and only addressed the part that applied to your brothers situation, which has no bearing on this thread.
Now that he's found the opening, I'm sure it will be marked so it's easily found again in the futre. Once you know where it is, digging it up is relatively easy.
Eddie
   / There must be a better way #33
About this time of year when it is just starting to think about getting warm the tank outline shows through the snow from the heat being given off by the digestive processes in the tank. That area is always the first clear spot.
I have an Infra Red thermometer (point it & take a temp of whatever it is looking at) I got from Harbor Freight for $50 or so.
I wonder if this would be sensitive enough to find a septic tank by warmth even without snow. Just walk around early in the morning before the sun is up & look for a warm spot...
   / There must be a better way #34
<font color="blue">Sounds like you're comparing your system to a different type of setup. Telling them to be smart and not bury there cover again because your brothers tank is that way isn't very helpful, and is quite rude.
Eddie
</font>
Now that he's found the opening, I'm sure it will be marked so it's easily found again in the future. Once you know where it is, digging it up is relatively easy.
The point I'm trying to make is here there are no covers on our tanks to be buried in the ground.
We must be talking about 2 different tank styles or designs.
Sorry I didn't mean to come off as rude.
Since 1966 I've either installed or had installed several septic systems and seen many more others.
Not once have any of them had buried access lids.
So naturally I would question this thing about covered access ports as discussed in this thread.
Burying my septic tank man hole cover would be as dumb as burring my man hole cover on my water meter pit.
You just don't do a silly thing like that.
   / There must be a better way #35
When we were looking at rural houses around here there seemed to be two styles of tanks. If the tank had an electric pump setup the cover extended above grade about 6" and had a cover that was chained and locked. If the septic tank was conventional gravity design the access cover was buried. The cover for the place we bought was buried about 1-1/2 feet and was a simple concrete lid. At the mandatory pumping and inspection for the sale, a riser with a sealed cover was installed. This riser came within 6" of grade. The digging will be easier now. It is marked with a landscape paver.
   / There must be a better way #36
<font color="blue"> We must be talking about 2 different tank styles or designs </font> That's my bet .... septic tank pump??? never heard that one. Mine works by gravity and my tank is buried with the lid about 18" down... there's a nylon string tied to the lid and a rock on the surface.
   / There must be a better way #37
Gravity is the kind we have at our place. Others such as mounds and some leach fields have two tanks, the regular septic tank and a receiver tank. The receiver tank takes the outflow from the septic tank and, using the pump, provides controlled doses of effluent to the bed. There are effluent filters somewhere in the system to prevent plugging the field.
   / There must be a better way #38
</font><font color="blue" class="small">( Gravity is the kind we have at our place. Others such as mounds and some leach fields have two tanks, the regular septic tank and a receiver tank. The receiver tank takes the outflow from the septic tank and, using the pump, provides controlled doses of effluent to the bed. There are effluent filters somewhere in the system to prevent plugging the field. )</font>
What are we leaching for here if the tank is an aerator?
MY FIRST CAR http://chevy.tocmp.com/chevyscrapbook/files/kamp50.jpg
OUR FIRST CAR http://www.hubcapcafe.com/ocs/pages01/chev6003.htm
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET TRUCK (A51406)
2012 FREIGHTLINER...
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A54757)
UNUSED RAYTREE...
