Think I broke 4wd
   / Think I broke 4wd #21
I have had a bunch of tractors small and large and have not ever broke a front end??
   / Think I broke 4wd #22
After 35 years of operating tractors 2WD and 4WD pulling an implement on the 3PH or draw bar if it hangs up the weight is usually transferred to the rear end and the front end gets light or lifts off the ground.
So I don't know how you broke the front wheel drive.
   / Think I broke 4wd
I don't know either but I should have some answers this time next week. I just hope it doesn't cost too much. I don't think it has anything to do with the box blade.
   / Think I broke 4wd #24
The only time I have heard of breaking front axles is by driving into a pile with the FEL in 4WD. If the load is too heavy, when you try to back out of the pile, the rear wheels can be off the ground or at least very light, so all the drive power is going to the front axles. This was common in early Rhinos and other Chinese mfg tractors, most of which came with AG tires.
   / Think I broke 4wd #26
I've got 400+ hours on my CK and it's never really been out of 4wd. I don't abuse the tractor, but it gets plenty of hard work. I am not worried in the slightest regarding the front end/4wd...it's one beefy unit and it's meant to be used.
   / Think I broke 4wd #27
any word on your tractor?
   / Think I broke 4wd
I used to leave mine in 4wd all the time. I read here some fella said that I should take it out if I don't need it. That was the way I used to operate my truck so it sounded right.
I'm wondering if leaving it in 4wd at the start may have weakened it. I don't see how it could as the tractor has never seen anything but a homemade dirt road and the woods. I don't think I overly hard on it from what I read here.
I wish I could be there when the mechanic opens the front end to see what gave. I think I'll ask them to save it for me so I can see the broken part(s).
   / Think I broke 4wd #30
the part that broke in mine was as small as the palm on your hand, since I saw the broken part I only use 4wd when its needed
2008 Bobcat T190 Compact Track Loader (A56435)
2008 Bobcat T190...
406 (A52706)
406 (A52706)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
Hook & Cable Strap (A59076)
Hook & Cable Strap...
