Third time a charm?
   / Third time a charm?
Sucks. FYI, It's about 1.5hrs to Plainfield, NH! :stirthepot:
Iknow! Thx for the reminder!
Finally spoke to the service guy and it seems I may have gotten the runaround last Wed. when I called for a status. At that time the person I spoke with had said that a brand new replacement block heater was installed and that it too was popping their GFI circuit. This morning the guy says he has had the heater out and on the bench and cannot make it fail. Hmmm...who's telling the truth?
I tend to believe the 2nd guy that I spoke to this morning. He started asking which "breaker" was popping and I told him my garage GFI ckt and all he could suggest is to "make sure it's a 20 amp ckt" which it is. I then went on to say that the outlets in the garage are the same ones that worked when the block heater was working last...with no ckt popping. Not sure what to think now except that they cannot bring my tractor back until next week as they don't do Saturday deliveries...no wood moving this weekend. :mad:
   / Third time a charm? #22
Not sure where you are but you can rent a trailer in Tilton for 4hrs for surprisingly little money.
I actually, have a small dump trailer that would be able to handle the BX but with the BH and FEL on, it would be hanging out front and rear...just didn't want to go thru the hassle.
Well the BX is back and according to the service tech he said they couldn't make it fail. I tried it again in the garage and it pops the GFI.
Tried it on the house outlet on the deck (separate from the garage) and it's fine...block heater heats up with no breakers popping).
Now I have to trouble shoot the garage outlets and see what I can find out. Everything else works except the block heater. Compressor, battery charger/maintainer, etc all work from the garage outlets.
Have a call into my electrician who wired my new garage a year ago.
Well, my electrician says that there is "something finicky" in the connection to the block heater that is causing the GFI to pop. In other words there is a "ground fault" somewhere between the block heater and the outlet. He said to try an adapter with no ground to see if that works. We'll see...
   / Third time a charm? #26
Can you try it in another outlet? GFI's can become weak. They are not without their faults. Pardon the pun...
Every outlet I plug into pops the GFI at the beginning of the circuit. I was thinking of trying replacing the GFCI outlet...thx!
   / Third time a charm? #30
Here is the thing. Gfci has another feature you haven't thought of. Its made to detect low levels of current and quickly shuts off. When the heater block ages it doesn't heat as efficiently when new hence low levels of current. Im sorry.. You might have to replace gfci to afci. The afci will trip if wired overheats ... Well... It supposed to that way. What size wiring is your circuit? 12 2? Are you using 20 amp plugs ? Hint it has a side slot on one of prong insert. Are you using a short 12 or 10 gauge extension cord?
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53472)
Koyker Loader...
MCDON D60 HARVEST HEADER (A51247)
MCDON D60 HARVEST...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
