This country girl needs help.
   / This country girl needs help.
Thank you!! Thank you!! Thank you!!
Everything was in the proper place (PTO, H/L, ...) but the high/low was tight. It started right up after I jiggled it a little. Again, thanks so much. I can't begin to explain to ya'll what an awesome feeling it is to be able to get all these things done around the house without my husband here. He still worries but so far, we've been able to handle all of it.
And thank you for the condolences and well wishes. Her brother is having a hard time with it. He's been laying on her grave most of the day.
Wish we'd get some rain so the grass/weeds would grow!! I want to get out there and mow. It really helps me relax.
Again, THANKS! I'll be reading everything ya'll great folks have already written. Who knew I was such a country girl??? :)
It feels like home.
I had actually finished mowing after fixing the shear bolt the last time I got to mow. (Have several shear bolts on hand now.) Being out of the seat doesn't cut off the engine. I must have had some good instructions because everything was in the proper place but the H/L was tight.
Also, once I told hubby about me mowing in 2nd and 3rd gear he said, "Oh yeah. I just told the kid that so she wouldn't get crazy and break herself or something else. I trust you."
We're flat, old cotton field here. Black gumbo. Drought stricken. Love it!
And, the glow plug ... so it's a diesel thing and not necessarily a tractor thing? Does it still need to warm the cylinders when it's 96 degrees outside? Just wondering.
Looks like I need to go take a picture of the tractor and had it as my profile pic. LOL Ya'll are a great bunch. Thanks again.
   / This country girl needs help. #13
No doubt if you could not get it running someone here would have come over and fixed it. Please let us know of anything else you need help with. It's the least we can do with your husband "over there".
   / This country girl needs help. #14
Curley thanks to you and your husband for his service. Sorry about the pup also. As to glow plugs at 96 degrees, will depend on your engine. My little Kubota will crank without their use at such temps with an extra turn over of the engine. My bigger Kubota does not even have glow plugs.
You probably know this but when mowing you need to run the engine to get the PTO speed to 540 RPMs which probably is shown on the tachometer. You then use the gear you need for the ground speed you need.
   / This country girl needs help. #15
Sorry to hear about the pup... we just lost one of our two cats to a fisher a couple of weeks ago; the survivor really misses his brother; sad to watch.
At the risk of sounding like a know-it-all, perhaps you'd like a brief intro to diesel engines..:eek:
Remember your physics classes? Charles' Law? Boyle's Law? Diesel engines don't use spark plugs- they rely on a compression ratio that's sufficient to raise the temp of the air in the cylinder, when compressed, to a point where the diesel fuel, sprayed in under high pressure, ignites all by itself.
The glow plugs are little heaters stuck into the air chamber to pre-warm the air; as you only get so much rise in temp (dependent on starting air temp and compression ratio), if the air is cold it requires a lot more work from the starter --remember the high compression in diesels?-- to start the engine.
The glow plugs are there to help that. Some modern diesels don't require glow plugs at all, some benefit from using them all the time, some only need glow plug help when it's really cold out.
My Massey-Ferguson likes some glow plug any time the engine's cold, but my VW Jetta doesn't need them at all unless it's below 5 or 10 degrees out.
Hope this might help clarify things a bit. Welcome to TBN!
   / This country girl needs help. #16
HI Curly
I trust you will be successfull.
I"m partial to all the military and other wise deployed family and family members. Hooah!
God Bless you all. I"m retired ARMY and fully understand what we all go thru with these deployments and changes we all go thru.
As you prepare for his return please do allow him to gradually fall back into the tractor loving relationship. Don't dump it on him and don't hold it for yourself. Yes releasing the tractor love is going to be hard as the family reorganization is tuff.
Take your time and do be Patient with him, yourself and the children and the Reassociation process can be a strain just as much as the separation.
God Bless and do know this too shall pass. IT WILL BE FIXXED
Larry
Ya'll are really friendly here and I am greatful.
The other puppy (Capt Morgan) was sleeping on Kahlua's grave this morning. He refused to eat last night.I'm already looking for another chocolate lab/mix to replace her. Well, not replace, but you know what I mean. I can't stand to see poor Morgan being so sad. Plus, my daughter and I miss her too.
As far as my husband, he's civilian with special request from the Marines. All I know for sure is that he got this DoD job because some Marines he used to work with in a civilian job requested him and got him there. He's been a heavy diesel mechanic ever since I met him almost 20 years ago. His excellent reputation is widely known in our area. This opportunity came up and we made the decision for him to go and live out some of his wargame fantasies. He should have been a Marine. He would have been so good at it.
He can fix anything. I guess that's why I'm so impressed with myself. He always makes it look so easy and I just don't understand any of it. Since he's been gone, I've fixed a water leak in the main line to the house. (Discovered the leak as I was driving up in the driveway after I had just taken him to the airport at the end of his first R&R.) Replaced the water inlet hose and valve to the dishwasher. Broke and fixed the shear bolt on the tractor. Dealt with honey bees making honeycomb in the water meter box. And all the other daily chores around the house. He calls me SuperWoman. lol
Anyway, for now everything is good with the tractor. I LOVE working with it. It will be very hard to give it up when he comes home. I've already told him that maybe he should try doing the housework. Maybe that will become his therapy so I can keep the weedeating and mowing for myself! LOL We're talking about having a mowing/landscaping type service once he comes home permanently. 'course I'll just be getting my nursing degree in May '10 so I guess the mowing business will have to wait until I retire from the healthcare industry in 20 years or so. LOL
Thanks everyone!! Ya'll have a Blessed Day!
Actually I did understand this part but thanks for refreshing my memory. My husband did a really good job of teaching the kiddo 'cause she in turn explained everything really well to me. He obviously didn't go into the glow plugs or things like that but as far as the operation of the tractor, he did a great job. And so did she for that matter. But, once I found out he had told her that she could only use 1st and reverse, I now understand why she HATED to mow. I don't blame her. But, that's okay 'cause now I'm in charge of it!! :cool:
   / This country girl needs help. #19
Hi Curly. Congratulations on what you have accomplished.:) I just want to say how impressed I am with your daughter. Your husband gave her instructions on how he wanted the tractor operated and she followed them to the letter despite hating it. How refreshing it is to hear that a child will do what they are told to do. I think she deserves some praise.:)
God bless your husband and keep him safe as well as all our military around the world.
   / This country girl needs help. #20
glad to hear things are working out. Lots of knowledge on here, I've certainly learned a lot - I hope you'll continue to ask any questions you can think of.
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
