This year's leaf vacuum
   / This year's leaf vacuum #21
For spent rifle/pistol casings I would imagine a lot of the rounds would be from bench rests, could be tricky with a large machine.
I would pick up a used backpack blower/vac
cut the suction hose install a sealed bucket/box to serve as a seperator install a piece of hardware cloth screen on the outlet hose fitting in the box.
Then just empty the bucket when full.
You could even mount the whole deal on a small four wheeled cart and extend the suction hose, just pull the cart along with you.
   / This year's leaf vacuum #22
It is action pistol shooting almost every week (4 times a year pistol, rifle & shotgun) most of the bays are 25 X 30 yards and there is no set shooting position. I too thought about using hardware cloth but I imagine I would spent too much time removing grass. We have been using this Home they were originally designed to pick up pecans and acorns; they too however pick up as much grass as brass.
   / This year's leaf vacuum #23
Due to the weight of the brass shells compared to the grass clippings, dropping them a couple feet in front of a fan would probably remove most of the grass. Then you have clean brass ready for reloading or sending to the scrap yard. A conveyor belt with a fan mounted under the end would allow you to dump the shells out on one end, allow them to scatter a little, and as they fall off the end the grass would be blown away, and a catch chute to channel them into buckets would be the last part.
David from jax
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2020 Ram ProMaster 1500 Van, VIN # 3C6TRVAG5LE100108 (A51572)
2020 Ram ProMaster...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
