thistle: mow or spray
   / thistle: mow or spray #41
Is it too late to spray a pasture in South Carolina with 2-4D to control thistles and other plates that are in competition with my fescue?
My experience is that 2,4-D works best in warmer weather when plants are actively growing. I would wait until next spring to spray.
Steve
   / thistle: mow or spray #42
This late in the year I think you would be better off to keep it mowed down to about 3" height. Depending on how warm your locale is you might have to mow it again. I would fertilize with a winterizer now and some of these are available with weed control. This is important as the roots will keep growing all winter, the best way to fight weeds is by having the grass roots choke them out.
Start in the spring with a good fertilizer regimen and overseed any thin areas, this has worked for me fighting thistle.
   / thistle: mow or spray #43
If you have access to a bunch of hungry horses, they would work well.
   / thistle: mow or spray #44
I fall spray for thistles here in Western Montana before the first frost . The plants must be actively growing to have an effect and with fall spraying a lot of herbicide will get to the roots since the plant is storing food for winter. I'd advise you to use something like Weedmaster (2,4-D plus diacamba)for a better kill.
Google on canada thistle for more info about fall spraying.
   / thistle: mow or spray #45
It should be the tail end of thistle season. I have not seen any thistle in a few month here in N. Ga along I20. You could still spray says the armchair 2-4d spray application tech. My pastures are generally Bermuda so I spray in early June and in the summer. Usually spot spraying and hand cutting and bagging thistle as we do not have a huge thistle problem.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2010 LONE STAR TRAILER MFG. GOOSENECK TRAILER (A53843)
2010 LONE STAR...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
