BobRip
Elite Member
In order to get moisture to build up, you need a surface cooler than the surrounding air in order to condense the moisture out of the air. I don't think you are going to find this typically on the inside of a roof, particularly in summer, as just about any daylight at all is going to make the roof warmer than it's surroundings. IF the attic space is cool, there is not much airflow thru it to draw in much moist air.
The moisture Bob was refering to being trapped, comes from inside the living spaces(showers, cooking, breathing ect...). There are some different ways of dealing with moisture, but it is generally excepted that it is best to have the insulation exposed to the air outside so it stays at least at the ambient relative humidity. Just like heat always flows to cold, so does moist flow to dry. Any moisture that finds it's way into the insulation from the inside will eventually evaporate into the air it is exposed to. Remove that ability to evaporate, and you will have rot and mold issues inside the walls. I think it is generally accepted as best to do all the sealing and trapping of moisture inside the living space(vapor barrier right behind drywall/plaster/paneling). The insulation keeps the inner wall warm and helps keep the moisture from condensing on the walls. The moisture content inside the home is controlled with ventilation typically...
Thanks for the elaboration of my too short explanation. Good job.
