three point fork lift mast?
   / three point fork lift mast? #1
BHD
easten Colorado
JD 4020
yes I have forks for my loader,
but one can not see,
hard on the front axels, (at times impossible), (have considered a review type camera on the loader to see the forks).
has any one build a 3 point unit for the rear of the tractor to work like a real fork lift?
if so have pictures and how do you like it,
   / three point fork lift mast? #3
The guy I bought my tractor from was a roofer and had the mast from a forklift mounted on the rear. It was homemade but worked for him. Sorry no pics didn't need it so didn't buy it
   / three point fork lift mast? #4
There was a guy around here that was doing something like that on small case lawn tractors. It was designed to pick up trees at nurseries. I think he sold about a 20 of them.
   / three point fork lift mast? #5
I see forklift masts with 3pt pins on it and a Sa hose now and then..
   / three point fork lift mast? #6
Didn't build it, bought it at an auction 10 or 11 years ago. Sold it 4 years ago when I sold the tractor.
Got to have a hydraulic top link.
   / three point fork lift mast? #8
Just saw one auctioned off, went for $325.
Max Lift Cap. 4,000 lbs. Max Lift Hgt. 70" Fork Size 1-1/2 x 4 x 46" Solid Fork Cap. 2,400 lbs. each Fork Spread Adjustable 20-48" 3-Point Hitch, Category II Lift Cylinder 2-1/2 x 42" Stroke Wgt. 675 lbs. Mod:40, S/N:747237.
Model:40
S/N:747237
Condition: GOOD
Probably should have bought it :(
   / three point fork lift mast? #9
How big is ur tractor. My old neighbor has arOund 100hp. With 2 really heavy duty fork lift mast he custom fab forto hook to a 3pt. He used them so load and stack hay. At least till he got a skid steer
   / three point fork lift mast? #10
Messed up once where I worked we had 3 or 4 old FL that were going to scrap, I DID get the forks and frame for them off one of them and other maintenance guy said take whole mast & make 3pt with it. I said just wanted frame & forks for FEL use... :/ Ya never said I was all that smart lol
The rest of the mast & truck was dropped into dumpster for scrap steel.
mark
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
LEEBOY 400T DOUBLE DRUM ROLLER (A52707)
LEEBOY 400T DOUBLE...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
11' CONTAINER (A52706)
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
toro turf sweeper (A50324)
toro turf sweeper...
