Three point lift arms
   / Three point lift arms #1
cop
MN
New Holland TC45
I have a New Holland TC45. Recently when lowering the backblade. I bounced it a litltle. The next time I used it, it would not lift. The front end loader works fine. After using the loader for an hour or so, w/ the three point lift control in the up position, the arms will be all the way up.I don't know if they will hold weight because I can't personaly lift any thing heavy enough to check it out. Any suggestions?
   / Three point lift arms #2
oil clean?
   / Three point lift arms #3
there is a shock relief ball and spring that squirt out a bit of fluid to keep lift seal damage. This over pressure release is located in the lift cylinder head assembly. Bouncing the implement hanging in the back causes quite a bit of pressure in side the lift system. if the ball is not seated tight against the seat then you'll not be able to lift to lift. that might be a possibility.
jc,
Clean enough to drink. Don't think I will. Good point though. My dad always said start with the easiest thing first
   / Three point lift arms #5
might have some crud in that safety or relief valve holdin her open?
soundguy
JC Thanks, I did have that assembly apart,wasn't sure what I was looking for. Didn't know what that whole thing was for. It all looked ok. Maybe when it warms up a little, I'll take it apart again
   / Three point lift arms #7
Look at the attached pdf (lift head, assembly #13 , ball and spring 17 and 18 might be the culprit. There is a outside chance that you have ruptured the list seal on the lift piston, item 45 and 46 in second pdf (lift cover)..
JC,
  • tc-45 lift head.pdf
  • tc45 lift cover.pdf
I dont like to think about taking that apart, but it may come to that. Thanks for the help
   / Three point lift arms #9
Sounds similar to what happened to my TC45DA. RickB suggested that I look on the top of the loader valve remove a plug and I might find that the pipe plug under it had loosened and was floating around. That's what I found all I did was clean the threads put the plug back in and I had my 3pt hitch again. Hope you are as lucky, about a 20 minute job. Attached is a picture of the valve laying on itside the top is on the left side. Plug #48 is the one you need to remove to access Plug #56 as I remeember it. Good Luck
I'll try that. I didn' think that was connected to the hydraulic power lift, but I can't argue with success.
PALLET TOTE OF JARS & MISC (A58374)
PALLET TOTE OF...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
Deere 325G (A57148)
Deere 325G (A57148)
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
FUEL CELL (A58214)
FUEL CELL (A58214)
