3-Point Hitch three point linkage
   / three point linkage #1
roy49
Anyone ever had any trouble with the little gear box that raises and lowers the right hand lift arm on a 4630? The crank handle works fine but the gearbox right above the lift arm will only turn about half a turn. There is no locking latch and the gearbox seems to be a sealed unit. Anyone ever had this problem?
Thanks
Roy
   / three point linkage #2
sounds like a broken tension pin that retains the bevel gear to the crank.
Look for and carefully remove snap rings to disassemble unit.
Mine was a one piece cast iron housing and cannot be sealed if they ever wanted it serviced.
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Bus (A50323)
Bus (A50323)
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
