The front drive shaft is dropped by means of a sliding collar just forward of the transfer case. There's no need to take off the "dash assembly" or fuel tank. I disconnected the steering lines at the pump, those big hex heads at the other end are too hard to get at. You might have to move some wiring for clearance when pulling the two tractor halves apart. Watch carefully as not to bend the lines when pushing them back together.
The front axle is on a pivot pin, so you'll want a pair of wedges right and left to keep the engine from tipping in one direction or the other after separation. Definitely do it on a cement floor, so you can move the rear half back and forth on a floor jack.
//greg//
