Thump in my F150 transmission
   / Thump in my F150 transmission #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I have a 1996 F150 V-8 with automatic transmission, around 80,000 miles. As I am driving down the road at normal speed, the transmissions bumps every now and then. I don't know how to describe it any better than that. It seems to do it more often if I am pulling a trailer. Does this sound like a precursor to more serious problems? Do you think a transmission service could potentially help alleviate or cure the problem? Anyone ever experienced a similar problem? I know answers will only be guesses, but I'm interested in hearing your opinions.
   / Thump in my F150 transmission #2
Get it seviced asap. Make sure they drop the pan and change the filter in addition to a back flush. My buddy just had the same issue on his with 230,000 miles. This cured it for the time being.
Chris
   / Thump in my F150 transmission #3
Torque Converter is taking a dump
   / Thump in my F150 transmission #4
Swap in Mercon V fluid while servicing. Also get a bottle of friction modifier from the Ford dealer. I was the Ford dealer transmission guy. Fixed a bunch this way.
I'm assuming its an AODE/ 4R70W. It has a mostly square pan with a single bump in the middle. If it's the E4OD then it takes regular Mercon fluid and it lightly needs an overhaul.
2006 KENWORTH (INOPERABLE)T800 (A55745)
2006 KENWORTH...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A57024)
2006 Magnolia Dry...
2011 GAYLEAN VACUUM 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
