(TIA) mini strokes??
   / (TIA) mini strokes?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
From what the doctor told me I had a mini stroke(Cat scan).Blood pressure is fine no high cholesterol no long lasting effects but some numbness.Any input??We walk every day,good diet.Getting older is a Bitc-
   / (TIA) mini strokes?? #2
Only advice if from watching my Grandfather in the 80's. He had a large stroke, and lost the entire side of his body, from the eye to the leg.
While he wasn't happy, he kept at it, and recovered around 95%.. lived another 15 yrs. to his 90s Whatever happens, don't give up. Never say I can't...
   / (TIA) mini strokes?? #3
Hopefully they won't get worse, Grandmother had them every couple of years for last 15 years before she passed at 92. Blood thinners required? Get your paper work in order just in case..........
Baby aspirin every day.Got paper work in order.
   / (TIA) mini strokes?? #5
BAM! Probably 20 years ago sitting around the dining room table with a bunch of buddies after a day of trout fishing. No warning no discomfort...... suddenly could not talk. Ono of the guys in the party was an
EMT and recoganized the stroke potential so things started happening pretty quickly including a helicopter ride to Traverse City (MI).
Diagonus TIA. No previous history, not over weight, active lifestyle, what the h—-?
Postscript to about April 2017. The good GP casually comments ‘ you’ve got a heart murmer’, I like for you to see a cartologest. Fast forward to September 28, 2017 and out for 7 hours in a well lit operating room to emerge with a qudripal by pass and new aritic valve the size of a quarter. Yet again, the whole experience unfolded with out incident or trama.
Thanking the Almighty my numbers not up yet.
B. John
B. John
Have 2 stints in the heart about 3 years ago.Always stay active we walk and get on the thread mill.Looking for 15-20 more good years,my fingers are crossed..
   / (TIA) mini strokes?? #7
TIAs differ from a 'stroke' in that they are considered Temporary. You have the symptoms of a stroke, but then they resolve. Both a stroke and a TIA come about from restricted blood flow to s portion of the brain. Depending on how big the area is, and the location, you could have something as simple as losing a memory to losing the use of an arm.
The difference between a TIA and 'stroke' is that the thrombus (clot) in a TIA is usually very small, and when it lodges in the artery/capillary in your brain, it shuts off the blood flow causing the symptoms you noted, but then it dissolves in short order, and blood flow is restored before any long lasting damage is done. A 'stroke' is the same thing except it shuts off blood supply long enough to cause irreparable damage. They are usually 'bigger clots' which cause them to take longer to dissolve and typically result in a larger area that is affected.
Think about an irrigation ditch which has several smaller ditches branching off. If you were to take a large 'clod' of dirt and toss it in one of the smaller ditches, it will roll along until it hits a branch point which is smaller than it is. It stops the water from continuing down that ditch and so the grass/crop which relies on that water suffers. If it blocked the flow long enough, the grass would die. That is a stroke.
A TIA is that same clod rolling along, getting stuck, but the water causes it to break up and dissolve. Yes, there was interruption of water to the grass, but it returned soon enough to keep it alive. Sometimes the grass can be 'stunned' and take a while to come back, but there are no long lasting effects.
The bigger the clod... the bigger the ditch it lodges in and therefore the more grass down stream, which is affected. It also makes it harder to be broken up/dissolved.
There is LOTS more information on this issue. This is the bare bones explanation of what is going on...
And yes... its what I do, so you can count on the information's accuracy.
Great info.Going to a neurologist monday and then follow with my heart doctor..Still don"t feel quite right.
   / (TIA) mini strokes?? #9
My wife had them over a period of about a year. No lasting effects. I had one about 2 years ago but the effects were gone by the time the EMTs arrived so it was never diagnosed as such. I now have arthritis in L4 lumbar vertebra that they are going to operate on next tuesday. Rather weak right leg but not sure if it is from the L4 or residual from the TIA. 83 now and out cutting firewood a couple times a week. Very lucky with the health problelms. Only bottom of the scale for high BP (124 for the high)
   / (TIA) mini strokes?? #10
That is great info!
Prayers coobie for some helpful information from your appointments. Something that points to a cause and then a solution. Getting older most definitely :censored:
2025 AGT QHT500FL Stand-On Self Loading Dumper (A55787)
2025 AGT QHT500FL...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
49" X 79" EXPANDED METAL RAMP GATE (A54756)
49" X 79" EXPANDED...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A55788)
2004 Sterling...
2016 Ford F-550 (A55788)
2016 Ford F-550...
Excavator Bucket (A53316)
Excavator Bucket...
