Tie Down Points on Trailer...Few Questions
   / Tie Down Points on Trailer...Few Questions #12
I'll have to call BS on that machinist. The top link where it leans over the top of the stake pocket is loaded the same way however you hook the chain to the pocket. Also, the chain is wrapped around something at the tractor end too where surely some links are feeling a side load.
Side loading an extra link at the bottom of the pocket is certainly worth the added safety to me.
   / Tie Down Points on Trailer...Few Questions #13
Skyco,
The problem with the two links you provided, is they are made for straps, not chains. This particular discussion was about chains, and although for most uses, a strap will or can be used, there are times when using a strap around machinery that the strap can be cut on the sharp edges. Most of us prefer the chains as a quality made 20K chain is better than a 12K strap. A little heavier duty can be reached with both, but those are usually the norm.
Straps also tend to be weakened by too many different things, for me to recommend them to the casual user.
Back on the chain note, if you really want a chain to be tight and don't mind the extra hassle, a ratchet binder is the cat's meow. Pain in the tuss to work with sometimes, but they will get a load tight and not as risky to use as a regular binder that sometimes slips and knocks your head loose.
I loop mine so the hook won't fall when and if it ever loosens.
David from jax
   / Tie Down Points on Trailer...Few Questions #14
sandman2234 said:
Skyco,
Look at the first link again- apparently you missed the part in the first link that says- "Accepts winch straps with standard flat hooks or chain anchors.
and you also failed to notice the pic had a chain slot in the device. The SECOND link is to a strap version.
Here is a PDF with more details on the first page of the STRAP and CHAIN versions-http://www.ancra.com/truck/pdfs/brochure_B220.pdf
   / Tie Down Points on Trailer...Few Questions #15
Actually I did see the chain, but considering a 3/8" chain is rated at over 20KSI, I can't see using something that is rated at 5500 as a method of hooking it to the trailer. Seems a hook on the chain would be better, less trouble and less to loose if it got some slack in it.
Sorry my post to you seems like I was attaching you, which is how it looks now that I re-read it. It wasn't intentional.
As far as the strap ratchet goes, they are probably as good as a utility trailer needs provided the owner keeps them tight. For securing some items, a strap is invaluable.
David from jax
   / Tie Down Points on Trailer...Few Questions #16
Hi All,
I have always doubted the strength of my stake pockets, simply because i didn't know how much they could hold. What i do is run the chains through the stake pocket and then hook onto the outside frame rail underneath. I'm sure the frame is strong enough and the stake pocket prevents the chain from sliding along the rail.
   / Tie Down Points on Trailer...Few Questions #17
What I did on my equipment trailer, was go around and weld some short lengths of chain at several places on the side of the trailer.
Then I hook chain to chain and binder the middle, or hook my binder into the chain on my trailer and the chain on the equipment on the other end.
They hang outside my trailer normally, and so far, have not created any issues.
I still need to spend some time under the tractor and work on better attachment points there.
If I make it quick and easy to do, the Boss will do it (My DW is owner operator of a landscaping / lawncare business) If it is hard to get done (such as when I had boomers not turnbuckles) sometimes it just does not get done.
I still have a constant fight to get 4 chains on the tractor instead of just 2.
   / Tie Down Points on Trailer...Few Questions #18
If we are going to do some welding then this is the preferred method.
AWDirect.com - DK7 Forged Angled D-Ring
Once these are on you can use chain with hooks or even better screw pin clevises to attach the chair to the "D" rings.
   / Tie Down Points on Trailer...Few Questions #19
Yea welding the chain link directly weakens the welded link from it's origional heat treated temper. I know trailer manufactures weld the links directly for the saftey chains all the time but that doesn't mean it is the correct way of doing it.
I don't know what their called but they make these rods in different sizes that look "U" shaped with a leg on each side to weld to the trailer so the chain link is not affected by welding.
   / Tie Down Points on Trailer...Few Questions #20
Somehow, I knew when I typed it, this would come up....
OK guys on the "welding it makes the chain weaker"
What exactly is the rating of your welded hooks, clevis's or mild steel stake pockets that you are wrapping your "rated" chain around?
The honest answer is you don't know. But you hook it up balancing convienience, ease and expense and make a good guestimate of strength based on experience with similar metals.
Very few are certified and rated welders on this board, even fewer work for trailer manufacturers in my experience.
Anyway, Jack, for me, that is not the preferred method as it makes an extra step in chaining things down, and takes slightly longer.
For the OP, you need to determine how often you will be moving / using it, and then weigh out your options from there.
2002 Chevrolet 3500 (A50120)
2002 Chevrolet...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
Takeuchi TB260 (A50120)
Takeuchi TB260...
2025 Platform Safety Basket Attachment (A50322)
2025 Platform...
2005 John Deere HPX Gator 4x4 Utility Cart (A50322)
2005 John Deere...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
