Tieing in a 8" pipe to 30"
   / Tieing in a 8" pipe to 30" #1
royalrebel
Tractorbynet1234
Hi all,
I'm installing a 30" HDPE culvert pipe. Nearby I have an existing 8" PVC runoff pipe that I'd like to tie into the 30". Should I use a T with Marmac wrap and use reducers. But without using reducers, any way I can cut a hole into the 30" pipe and stick the 8" pipe into it and use foam and Marmac to seal it up or will this not hold up in the long run?? Any advice is appreciated. Thanks
   / Tieing in a 8" pipe to 30" #2
I have made those type of joints when installing field tile and teeing into a large county main line.
I cut the proper size hole into the large main and stuff my little (~6") line into it. Then cover the joint with a plastic garbage sack to seal the joint slightly, pour 1 or 2 bags of premix concrete over the joint and gingerly backfill the ditch.
There is enough moisture in the soil to harden the concrete. If you're concerned there isn't enough moisture, add some before the joint is fully covered with soil.
   / Tieing in a 8" pipe to 30" #3
Not an expert, but I also thought people use concrete for that.
   / Tieing in a 8" pipe to 30" #5
Not on the same scale, but I do alot of ag drainage. Corrugate pipe (tile as we call it)
Its uncommon to see mains much over 12" diameter. And often times we need to tie 4" or 6" laterals into the main. Yet the specific "tee's" to reduce to that size are $$$
So we simply use the appropriate size hole saw to cut the main. Then use a coupling sometimes to snap the smaller pipe in, or ADS actually makes what they call a "tap tee"
No need to be perfect or "sealed" cause with drainage pipe....you want water TO GET IN. And its slotted anyway.
   / Tieing in a 8" pipe to 30" #6
   / Tieing in a 8" pipe to 30" #7
That was a good video.
My employer would have never spent the coin for a 5, 6 and 8" hole-saw. He would buy a sack of 5 & 6" connectors.
And he refused to put in 4" tile, saying it would blowout on a long run.
2016 Toro Reelmaster 3100D 72in Reel Mower (A46684)
2016 Toro...
72in. QT Fork Frame w/42in. Forks (A46502)
72in. QT Fork...
Deere 544G (A47307)
Deere 544G (A47307)
Skid Steer Jib Pole (A46502)
Skid Steer Jib...
3081 (A46502)
3081 (A46502)
2011 Ford F-250 Pickup Truck w/ Liftgate (A44572)
2011 Ford F-250...
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
Please support our site by disabling your ad blocker.
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
