Tiller Durability? Roots?
/ Tiller Durability? Roots? #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Cab Backhoe (sold), John Deere F725 Front Mount Mower, Kubota LX3310 cab.
I am thinking of buying or renting a tiller someday but I am concerned about durability. My land was a timber stand that was cut a few years back. I have been digging the stumps and clearing for a while. I have run my disk harrow over it a few times but it's still a bit rutty and I think a tiller might tame it some. Every so often I kick up a piece of buried wood or some roots.
Will a tiller withstand the occasional chunk of wood or will it bend the tines or worse? If I found one to rent do rental companies offer insurance against damage or would I be liable for any bent tines, broken gearbox, etc?
/ Tiller Durability? Roots? #2
A tiller will normally hop up out of the ground when it hits a larger root or rock. If it gets hung up on one the slip clutch will stall the rotation and prevent most damage. If it were me, I'd rent one to see how it handles the ground. I think the more likely damage to a tiller will be longer term with bearings and seal failures if it is bounced around a lot with roots.
/ Tiller Durability? Roots? #3
What kind of timber? pine or oak? How much land redoing? Especially if it was a large area with oak stumps id price someone with a subsoiler to come in and work over it.
/ Tiller Durability? Roots? #4
I agree run through it with a subsoiler, or gang plow. As for durability my Ansung listed in my signature would work find and stand up to what you have.
/ Tiller Durability? Roots? #5
Depends on the tiller!
The "good" ones cost money, but you won't break them on roots or stones either... A cheapo tiller won't take heavy abuse...
I'm coming up on 2000 acres on one of my Howards and I've not broke or had to replace even one bearing/chain or anything else inside of it...
SR
Thanks for all the input. I was mostly concerned about renting one and having it tear up. I haven't even checked to see if they are available to rent in my area but if I was going to be liable for damage I would just buy one and be done with it. I don't need one bad enough or often enough to own it if I don't have to.
/ Tiller Durability? Roots? #7
Most rental companies offer optional insurance coverage at a reasonable extra charge to cover potential damage .
Any quality tiller will have a slip clutch and if set up and maintained properly will prevent tiller damage.
/ Tiller Durability? Roots? #8
I've hit a few things with both the Troy-Bilt walk behind and the 4' Taylor Pittsburgh. Usually rips through whatever. A few times I've been stopped in my tracks (with both). Haven't broken a tine or gear yet (knock on wood). Sometimes roots will wind around the tines and shaft, then bind. Takes some time with pruners and other types of cutters to get them cleared.
/ Tiller Durability? Roots? #9
Yes, set and maintain the slip clutch properly and the tiller will be fine.
/ Tiller Durability? Roots? #10
A
SR
King Kutter is one of the least expensive tillers out there and is well built. The Landpride 12 series on the other hand is the low end of an expensive name brand line with known unresolved manufacturing issues the company refuses to correct.
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2010 Case 580N (A60462)
2010 Case 580N...
2007 Ford Taurus Sedan (A59231)
2007 Ford Taurus...
Godwin CD150M Dri-Prime Towable Trash Pump (A59228)
Godwin CD150M...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61307)
Bulk Lot of NEW...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
