Tiller Gearbox Cracked
   / Tiller Gearbox Cracked #1
jbrumberg
Elite Member
Cummington, MA
New Holland TC29DA, John Deere D130
To All:
The gearbox on my Woods T-42 tiller sustained a ~3" hairline crack on the bottom third of the gearbox many years ago. Each spring and before all tilling I have to refill the gearbox with SAE 90 gear lube. I am amazed that this tiller still works. I am curious as to how I can best repair this crack. Any suggestions would be appreciated. Thank you in advance for your responses. Jay
JC: I never heard of JB Weld before. I did some online research and it appears that this epoxy will meet my needs. It's interesting because I completely resurfaced my boat below the waterline with epoxy 10 years ago and it is still holding up. I had always wondered if the "epoxy solution" would work- I'll give it a shot. Thank you. Jay
   / Tiller Gearbox Cracked #4
The JB weld may work, if it does, the surfaces have to be absolutely free of all oil. That is a pretty high vibration environment too, which may make it fail in the future. Better solutions would be to have it silver soldered, brazed or welded with a nickle rod. It's cheapest to take the guts out of the box first, but a good shop would probably do the remove and replace too. While this may seem like a lot of extra work, to do the epoxy correctly, you should take the guts out too and completely degrease it too.
jb
   / Tiller Gearbox Cracked #6
You could also Braze it if you have the oxygen & Actelyne torch setup, As stated by previous poster drilling holes at the end of crack will stop further cracking and just need filled in with brazing rod...
   / Tiller Gearbox Cracked #7
If you can disassemble the box, ad clean it.. I'd silver solder or braze it.. or jbweld it from the inside.. should work fine..
Has to be 100% clean for any of that to work. Might want to drill 2 small stop holes.. one at each end of the crack.. use the smallest drill you can find... make sure to fill those holes with a good slather if you jbweld it.. etc.. check for gear clearance too..
Soundguy
John, Rick, Mark, & Chris: Thank you for your informative input. I will start with the JB Weld with "drill points" and see what happens. Jay
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2021 JOHN DEERE CP690 LOT IDENTIFIER 182 (A53084)
2021 JOHN DEERE...
Case Maxxum 140 (A50120)
Case Maxxum 140...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
MURRAY 22" 2N1 SELF PROPELLED GAS PUSH MOWER (A51248)
MURRAY 22" 2N1...
