tiller sizing, remove row of cutters?
   / tiller sizing, remove row of cutters? #1
koshari
Kioti ck35 , Deutz agrolux 4.80e, Deutz Agrotron 6.00 TT, Kobelco sk30ur excavator.
There is a tiller going locally which is not to far to go and is pretty well priced but its a 7 row, we have a 35hp which i think will be marginal, seller was running it behind a 45. could i disconnect the 2 outer tiller blades therefore making it a 5 row tiller to lighten the load on the pto?
   / tiller sizing, remove row of cutters? #2
You can but the rotor without tines will interfere with depth control and the unprotected rotor flanges will wear rapidly and soon will not be able to accept tines should you decide to reinstall them. If you have a hydrostatic transmission try tilling with all the tines.
   / tiller sizing, remove row of cutters? #3
I run a 6 ft tiller (seven sets of tines, but 6 on a node -- not quite sure what you mean by rows) behind a Kubota L3400 (geared). No problem in worked soil, will require two or three passes in established sod. Our soil is mostly clay, with a very shallow organic layer.
   / tiller sizing, remove row of cutters? #4
I have removed tines with no problems noted.
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
378812 (A51573)
378812 (A51573)
2005 FORD F-650 (A52472)
2005 FORD F-650...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
