Tiller - Slip Clutch
   / Tiller - Slip Clutch #1
Glenn67
Mahindra 1815 HST
Good morning all,
I purchased a Mahindra 1815 HST from a friend a while back and have a question.
It came with a 50" rototiller and when I use the tiller it continually pops the clutch,
I have read that you need to run a slip clutch when using these implements, does
anybody know if this might help my situation?
Thank you for your suggestions.
Glenn
   / Tiller - Slip Clutch #2
Did you mean to say it has a shear bolt and keeps breaking it?
I think most tillers will use a slip clutch driveshaft. It is equally important to make sure it will slip to protect the tractor.
I just loosened the bolts on mine and slipped it then adjusted them back. I am going to draw a line on it with a grease marker to make sure it will slip.
When I got my tiller the slip clutch was tightened all the way down and rusted together. I had to remove the bolts and tap it apart with a hammer.
   / Tiller - Slip Clutch #3
A slip clutch need to be spun regularly. I spin mine yearly on my slip clutch equipped implements. I use a Torque wrench to reset them by locking the driveline with a suitable bar and setting the breakaway torque to 200 foot pounds. Your breakaway torque value should be listed in the manual that came with the tiller.
If it's breaking a shear bolt, the breakaway torque is set too high. It should slip before the shear bolt breaks (if you have one).
   / Tiller - Slip Clutch #4
Its my observation from many yrs operating/repairing farm equipment that slip clutch maintenance is one of the most overlooked component on equipment servicing.
   / Tiller - Slip Clutch #5
That and starting batteries and their (often corroded) connections.
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
(14) Round Alfalfa Bales (A50515)
(14) Round Alfalfa...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
