tiller vs discs....which is best for prepping clay soil for sod
   / tiller vs discs....which is best for prepping clay soil for sod #1
DPForumDog
bham
not yet
I want to smooth and de-rock our clay soil to prepare it for sod. Which is best a tiller or discs?
What is the true purpose of each?
Thanks
Granny DP
   / tiller vs discs....which is best for prepping clay soil for sod #2
Both the Disc Harrow and the PTO powered Roto-tiller are different forms of soil mixing tillers.
Disc Harrows have to be pretty heavy in order to cut well. Generally speaking 18" diameter pans are the minimum, therefore around a 30 horsepower, 4-WD tractor is required to pull a Disc Harrow with 18" diameter pans at the brisk pace necessary to mix soil. A Disc Harrow is a secondary tillage implement. Usually new ground must be "opened" with a plow before a Disc Harrow is effective. Once plowed, a Disc Harrow can maintain tillage if used once or twice per year. Disc Harrows are most often used in fields.
(Quite a number of variables to be considered.)
Roto-Tillers mix soil well on even 20 horsepower tractors. Roto-tillers are preferred for garden situations, where short pulls, rather than long pulls, are the norm. With repeated coverage of the same ground, may prepare unplowed ground. Best paired with an HST tractor transmission because forward movement will be slow while the implement churns the dirt. After being prepared with a Roto-tiller most soil is seed ready. For sod preparation, use a Roto-tiller.
In summary: small area, small tractor = Roto-tiller. Field work, larger tractor, heavier implement = Box Frame Disc Harrow. Both are soil mixers.
With either implement be cautious not to overwork the clay or it will become adobe brick when dry. Work in as much organic matter, preferably composted organic matter, as possible.
Removing rocks usually requires stoop labor to deposit rocks in the FEL bucket or a trailer.
Thank you, that was very informative.
   / tiller vs discs....which is best for prepping clay soil for sod #4
I think either piece of equipment might work, but I would use a tiller. If your yard is all high clay content, I would have several loads of good topsoil brought in to lay about 4" deep then run a tiller over it about 6" depth to mix it in with about 2" of the clay soil. After 2 passes with the tiller and then hand raking to level out any high spots or furrows, run a roller over it to lightly compact if putting down sod.
If sowing seed, then seed directly behind the tiller then lightly rake to cover the seed and fill in furrows/level any high spots then lightly compact with a roller.
High clay soils need a lot of organic matter in order to absorb moisture and hold it. Without the organic content, rain (or sprinkler) just run off and not much of the moisture penetrates. It is better to spend the money to prepare a good bedding for the grass now than fight constantly to have a good yard on hard clay.
Thanks,
we have a JD5203 and I was just wondering what implements to buy.
I pull a 7ft bushhog, so I think I could handle a good size tiller.
Thanks
Granny DP
   / tiller vs discs....which is best for prepping clay soil for sod #6
Why not enter your JD5203 in your T-B-N profile? Your responces will be more useful.
   / tiller vs discs....which is best for prepping clay soil for sod #7
Best topsoil I ever put down was 3/1 black dirt and sand mixed in a pile with a loader .
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2020 CATERPILLAR 305E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
8' SMALL FENCE POSTS (APPROX. 40-50 PC) (A54756)
8' SMALL FENCE...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED FUTURE SG45 - 45" HYD STUMP GRINDER (A54757)
UNUSED FUTURE SG45...
