Tilling and rocks...technique question...
   / Tilling and rocks...technique question... #1
adegiulio
Red Hook NY
JD 4310
I am building a house in Dutchess County, NY...Our soil is basically clay and rocks. Some of the rocks are volleyball size, some are softball sized, and some are shoebox sized. Basically, I have a lot of rocks. Everytime I try to smooth an area with the FEL, I pull up some more. I would eventually like some gardens and food plots. When tilling, what would people recommend to keep my tiller from disintegrating. I haven't bought a tiller yet, but I assume I am in the market for a gear driven model with a clutch. I am nervous that my first time out I will hit a nice big rock and fry the clutch...
Any help would be appreciated, even models that might hold up well in clay and rocks...
Thanks
   / Tilling and rocks...technique question... #2
One approach would be to get a scarifier type implement and run it at 4-6" depth making several passes to pull loose all the rocks. Of course, then you have to pick em up......
That's all I know.
Ron
   / Tilling and rocks...technique question... #3
Tillers and rocks don't keep good company and you will want to remove as many of the rocks as possible from any area you will be working with a tiller - particularly if you will be going through it every year.
From your description of your rocks, I'm wondering if you wouldn't be better served working the areas with a 3 pt disc harrow or some other implement at least for a few seasons and until you get the rocks under control somewhat. Unfortunately, rocks are like weeds... there always seems to be a new crop, no matter how many you have already removed!
If you do go ahead with the tiller, you will find you get pretty good at lifting the 3pt and releasing the clutch in one quick, seamless motion every time you snag a rock. You probably won't fry the slip clutch, but those rocks sure give the tiller tines and drive mechanism a beating!
   / Tilling and rocks...technique question... #4
My wife suggests raised beds for the garden. That may not be practical, however. I dug our garden area with the dirt-digger first to unload any of those gremlins. Then I went across it with the tiller. Still got some potato sized ones. We have planty of sand around here, but it's still a rock farm like yours. I'm in south central Michigan and I'm sure the winters aren't as severe as yours, but it's an interesting phenomenon about those rocks. The frost manages to ease them to the surface. We may have cleaned the top course this year, but there's a new crop on the way!
   / Tilling and rocks...technique question... #5
Removing the rear flap on the rotatiller may stop some rocks from rebounding and jamming between the tines and the top of the tiller. Also keep several spare tines on hand.
Try and pick a tiller with as much clearance between tines and body as possible.
Can not advise on brand or type.
Attached is picture of rocks mine has located and I've picked . This picture has been posted before.
Egon
   / Tilling and rocks...technique question... #6
The advice about scarifying is very good. Get as many rocks that way as possible. That said, no matter how careful you are the tiller is still going to find some (maybe many). So, go slow and make multiple light passes if possible. Be ready to hit the clutch b/c the tiller will find rocks it cant dig out. In this case it will jump around wildly. Oh, also keep a pry bar and shovel handy in you loader bucket. Going slowly helps alot.
   / Tilling and rocks...technique question... #7
I haven't built it yet, but plan to take the scarifiers off my box blade and make a five tooth ripper with them. Plan to have some gage wheels to set a an adjustable depth of 4-8" or so. I figure when I till a lot of unknown property, I'll crisscross it several times with the rippers to get below the tiller depth. Should make the tilling much easier and compensate for the time spent ripping.
My two cents.......
ron
   / Tilling and rocks...technique question... #8
Rocks are really big. So, I say rent a rock picker first and then buy any tiller. Small size rocks won't be a problem, but yours are of volleyball sizes.
   / Tilling and rocks...technique question... #9
It the scarifiers bring the rocks pretty much to the surface, you may want to try a landscape rake before picking them up by hand, although I don't know if it would work well with rocks as large as yours. Anyway, it's a thought, and might save some on the manual labor.
And, if the scarifiers don't pull up the big rocks, a middlebuster might bring 'em up the surface.
OkieG
   / Tilling and rocks...technique question... #10
How does a rock picker work on 50 year old sod ???
How does my B7100 pull a rockpicker???
Not sharp but can count to ten before I'se gota take my shoes off.
Egon
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2014 Ford F-250 Knapheide Service Truck (A48081)
2014 Ford F-250...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2009 Mini Cooper Clubman Sedan (A50860)
2009 Mini Cooper...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
