Tilt valve on Bob Cat will not work
   / Tilt valve on Bob Cat will not work #1
Lorcan
Ireland
Bob Cat S175
Hello
I bought a Bob Cat S175 (06) with 1500 hours. Its got all hand controls. Was working good. About 2 weeks age got into it and when you press the activate button on the left hand side all lights come on but the Tilt Valve light does not. On the left hand side the ACS light comes on. The hydraulics will not work. None of my local mechanics cannot help and my dealers in Ireland dont exist as far as i can see.Can anyone please help. A friend reckons its a solenoid on the ACS block. When I looked the is 3 solenoids i think took two apart looked ok. The third i cannot access. Also tried disconnecting the battery. There is also a problem code coming up 32-04. Can anyone please help. I really need this machine going in the farm yard.
Regards
Lorcan
   / Tilt valve on Bob Cat will not work #3
Code 32-04 is "No communication from ACS controller". Solenoids on the vavle do not affect this.
There are multiple reasons that could cause this. First thing to check is ALL fuses, fuse #10 & 12 both supply 12 volt power to the ACS controller.
Problem could also be loose connection at controller(s), broken wire in harness, actuator shorted out and this might cause internal failure of the ACS controller.
Hi checked the fuse and they seem to be ok. Now where is the actual controller situated and what does it look like. Also what are harness pins and plugs in the wiring. I f you could help me i would appreciate it.
Thanks Lorcan
2022 International CV515 Ambulance, VIN # 1HTKSSWK7NH675363 (A54865)
2022 International...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55302)
2019 BOBCAT T630...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A55787)
2018 John Deere...
2023 G Bar K Goose Neck Flat Bed (A55218)
2023 G Bar K Goose...
