Time for a new furnace. What kind?
   / Time for a new furnace. What kind? #21
I currently have an electric heat pump with propane backup heat. I'll be replacing it with a geothermal system in a few weeks (currently planning the layout now).
It's important to understand exactly how an electric heat pump with gas backup actually works, because it's often glossed over. Unlike an electric heat pump with resistance heat backup, the gas backup heat doesn't supplement the heat pump, it replaces it. The two do not run together. It isn't even sensitive to how well your house is being heated. A gas backup system has an outdoor thermostat and when the outdoor temp gets down to a certain level (35-40 degrees seems common), the electric heat pump switches off and the gas furnace heats the house. So for all practical purposes when it gets cold out you are heating with a pure propane furnace.
I strongly recommend that you download and run this spreadsheet before making any decision on type of fuel, especially if you are considering doing anything with propane. http://www.eia.gov/tools/faqs/heatcalc.xls. People like to talk about how expensive a regular heat pump is when the electric resistance heat strips kick in, but get the real numbers. I worked them using my local rates and prices and found that propane is so expensive it simply isn't competitive. I found that in my area, the propane backup costs more than the electric resistance backup when the price of propane exceeds $2.20 a gallon. Which it consistently has every winter for last several years. And don't forget, with propane backup, you're running on pure propane heat, not simply supplementing a more efficient heat pump like electric resistance backup does.
Just an anecdote, a friend of mine complained during the polar vortex January that his electric bill went up $200 because of all the resistance heating that his electric heat pump was using. Sounds bad, but for that same month, my propane bill was $850(!).
The tax credits and rebates make geothermal very attractive and can bring geothermal down to the price of a conventional system or even a little less. As others have said they are quieter and more efficient, but hey also last longer... 10 year parts/labor and 50 year parts warranties aren't that uncommon. Also, at least around here, geothermal systems don't require any kind of backup heat unlike air source heat pumps. This is because the ground temperature is relatively constant so the system can always develop heat from the ground, which can't be said for an air-source system.
Another thing to consider that hasn't been mentioned is refrigerant. With a 25 year old system, you are likely using a type of refrigerant that has been or is being phased out. You will still be able to get it after next year, but at a rapidly escalating price as they will not be making any more, to the point where refills may not be economically viable. So in my opinion if you have an economically viable opportunity to replace the system now, you should do it.
Sorry for the long post, but since I'm in the middle of doing a replacement now, I can identify with this thread.
Country Geek, thanks for the feedback. I'm pretty sure I've heated our house and made hot water some years for $850 or a little more using propane. I'm talking all year. I don't know if our house is well insulated or what.
You explanation of the heat pump with a propane backup is what the furnace guy explained to me. As it sits, I don't really have a problem with the cost to heat our house in a year, but saving money would be nice.
I took a look at the spread sheet, it does look like propane is one of the more expensive ways to heat. I'll have to look at what our electric rates are.
   / Time for a new furnace. What kind? #23
I took a look at the spread sheet. Propane efficiency 78% for furnace or boiler?? 65% for vented room heater?? Price of propane $2.93@gal.??
I looked at our electric rates and ours matches the spread sheet. Even changing the propane cost to $2 a gallon and bumping up the efficiency of the furnace to 92% propane costs quite a bit more. I'm probably burning between 600 and 900 gallons of propane a year. I also looked at some other websites and it sure looks like geo pans out.
It also looks line the tax breaks are in place and the power company gives you a break on the rates for geo.
   / Time for a new furnace. What kind? #25
Geothermal is the only way to go. We've had a geothermal system for seven years now and heat and cool about three thousand square feet of living space every day for less than lunch at McDonalds.
   / Time for a new furnace. What kind? #26
Friend of mine who has done HVAC his entire life (lives in the Quincy IL area) wasn't crazy about heat pumps either. Too cold but said they would probably be a better option where I live now since we have warmer winters. A co-worker did the geothermal and he said it's great.
   / Time for a new furnace. What kind? #27
Does it make it hard to sell them when you don't like them?
No , some people will have nothing but a trane. You can't talk them out of it. They believe the commercials .. You know ''it's hard to stop a trane''
   / Time for a new furnace. What kind? #28
Geothermal. It is the way to go. Outside woodboilers are under heavy EPA pressure. And they do not give up.
   / Time for a new furnace. What kind? #29
You're supposed to modify it to plug in the correct values for your equipment and local prices. I think the values they start with are nationwide defaults.
   / Time for a new furnace. What kind? #30
Wow, that's impressive. If my propane bills were that low I would never consider anything else.
I'd be curious to know more about how you do it. Is propane really cheap where you are?
For example, my 1999, 50 gallon propane hot water heater has an energyguide sticker that says it can be expected to use 277 gallons/year. According to the scale on the sticker that makes it among the top 25% most efficient (in 1999, though). At our current propane summer prices of about $2.20 gal, that would be $610/year for just hot water. But during the winter prices spike so I think it would be conservative to say that hot water alone costs me at least $800/year in propane. (Yes I plan to replace it as soon as my geothermal heat pump project is done).
I've been pretty diligent about keeping track of my propane usage since 1999 in an excel spreadsheet, and during the summer months my usage appears to be a bit under 1 gallon a day, which squares with the energyguide estimate on my hot water heater. I say "appears to be" because I can only calculate usage between fill-ups and I I've never had a purely summer fill-up. The tank always gets filled in March or April, and then again in October.
24ft T/A Enclosed Cargo Trailer (A53424)
24ft T/A Enclosed...
2596 (A54757)
2596 (A54757)
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
