gearmaker
- Joined
- Jul 5, 2014
- Messages
- 15
- Location
- Hillsborough,nc, Mountain City TN
- Tractor
- NH TC30, MF135, Bobcat 763, Ditch Witch 4010
Hey all; Lurking for a couple of years, first time posting. I have a new to me 67 135 Continental Gas Z145. I am at a loss how to time this particular beast. Runs hot under load. I do have the Owners manual, parts manual and service manual. Static timing ( index marks thru hole lining up as well) yields rotor 180 degrees off. Can the distributor be pulled out and rotated 180 degrees so the timing marks line up? Not clear in the manual. The Distributor Has little adjustment as their is interference with the power steering reservoir impeding rotation. I have rotated the wires one notch then I am a little to far advanced or retarded depending on which way the wires are moved. Can the Power steering reservoir be rotated? It is offset in relation to the gear driven pump. I see one screw in the exploded parts diagram attaching reservoir. Over all tractor is in fair shape. Has a loader that I cannot identify,which I am currently switching to Front pump from diverter feed. 2400 hours. Running hot when loaded with PTO 210-220 degrees. It has a new radiator and I put on a new water pump. Hoses were kinked so I replaced with molded hoses from Yesterdays tractor. New thermostat ( ran without last summer for test no change) Overhauled Marvel carb but without correct timing tough to adjust. New points, plugs, condenser and wires are new. Governor is non-responsive So I will pull the cover and inspect. Fat blue spark.
thanks for reading. I will post pics.
David
David
