Forks Tip ends on homemade forks
   / Tip ends on homemade forks #1
Arky217
Hartford, AR
Kubota L4200
I'm making a set of chain on bucket forks for my pin on bucket for use mainly on brush, slabs, etc.
I'm using 2"x2"x1/4" sq. tubing and will be putting about a 30 degree angle on the points.
Trying to decide whether to put the slope of the angle up or down. I've seen them both ways.
Which way would you orientate the slope of the tips and why ?
Thanks,
Arky
   / Tip ends on homemade forks #2
I like them angled up so they will tend to ride the surface (instead of digging in) while I am sliding them under an object. Mine are only 1" tall. You could also make them reversible or compromise with a double taper.
   / Tip ends on homemade forks #3
My first inclination would be upwards so as to not catch the bottom of a pallet etc. but since those tubes are pretty thick compared to solid forks, maybe the double taper that Brad just mentioned would be best, so you're not spearing the ground as easily.
JB.
2018 New Holland C227 Compact Track Loader (A55315)
2018 New Holland...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
10' CONTAINER (A52706)
CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
CATERPILLAR...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
