Renob
Fish,
As others have eluded to, the use of a box blade is somewhat more art than science. Practice and experimentation with box set-up and technique are all that you can do to master the Zen.
As for your hitch.... It will float UP at whatever height you set it at. Trust the others and me, it does. You can test this by setting the hitch at a given height (no implement connected) and simply lifting on the hitch arms. They should easily lift up.
Now to get rid of the washboard effect try the figure 8 and cutting at 45 degree methods. This takes many passes.
The ultimate may be the gague wheels. With these you can in effect float the box up and down because the wheels won't let the box dig in. What I mean by this is without wheels if you lower you box till it hits the ground then continue to lower you hitch, that box will try to dig until the hitch stops it. With the gague wheels it can't dig deeper than the wheels are set, but can follow ground contour, not hang the box up in the air as you have experienced.
Anyway good luck and know that you are not alone in the lack of BOXBLADE ZEN department.
