Snow Equipment Owning/Operating Tips on using FEL to remove snow
   / Tips on using FEL to remove snow #21
Just wanted to add if you look back in this thread (rus_geek) you'll see this link
TractorByNet.com - Compact Tractor Forum
to a thread that basically advocates for these. Only instead of going through all the time of hand-building them, I just bought 'em. Not the cutting, welding, testing, painting, drill into my bucket kind of guy. One question I have for anyone out there with a BX is if they found a weight box useful for traction in the snow? I don't have one, and we didn't get more than 6-8" at any given time though it was at least once a wet snow, but even with these on my bucket I can only get so far before the traction's just not there. I have R4 tires I filled with I believe with calcium chloride (bought it secondhand). Any thoughts?
   / Tips on using FEL to remove snow #22
I usually set my bucket down and curl it just a few degrees upwards so it doesn't bite into the ground. You can use down pressure or float. Practice makes perfect. I wouldn't bother buying those things. Rolling the bucket a few degrees does the same thing.
I do as you but what we both do is put the wear on the bucket, with these the wear would be on a less expensive, wear part and your bucket would be intact.
   / Tips on using FEL to remove snow #23
hmmm shut up and take my money LOL
honestly I like that.. i know i can curl the bucket, but that would take the thought out of it..
Brian
2017 JCB 510.56 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 JCB 510.56...
23018 (A55758)
23018 (A55758)
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
UNUSED PABREAK RT260 - 72" HYD TILLER (A57193)
UNUSED PABREAK...
