Tire Ballast--again. Sorry.
   / Tire Ballast--again. Sorry. #51
</font><font color="blue" class="small">( assumed it was because no one was sure.
)</font>
Aside from the few of us that just guess and mix.. I'm not sure there is any hard or fast info out there on low ratio AF mixes..
</font><font color="blue" class="small">( many thermosyphon engines run 30/70)
However, if I can't go any lower than 30/70, that's still pretty expensive.
)</font>
They are running 30/70 to keep freeze resistance. On thermosyphon systems, lower antifreeze ratios are actually better. For instance.. a 50/50 mix has been reported to cause hot spots and circulating problems in thermosyphon systems.. Many thermosyphon systems reccomend distilled water for non-freezing environments.. due to the better circulation..
Here's your chance. Go grab a handfull of cheap grade 2 hardware.. mix up a couple glasses of various strength af/water mixes.. and let them set.. and record corrosion progress over time.
( Keep in mind that reccomended fill in a tire is 75% so that water level is over rim.. thus lowering oxygen contact with the metal).
This is another reson I like tube tires.. as long as the tube is intact.. no fluid hits the rim.. etc.
Soundguy
   / Tire Ballast--again. Sorry. #52
)</font>
)</font>
Soundguy
   / Tire Ballast--again. Sorry. #53
</font><font color="blue" class="small">( say 1/20 or 1/50 AF to water (which is what you hear most commonly )</font>
Ok.. i just went and checked my tire size on my 8n.. I had 1 gallon of af in my tire.. and my data shows 27g to 75% fill..
So there you have it.. I did a 1:27 mix.
I had those tires filled from 2000 thru mid 2004 when i lost a rear tube, got new tube/tire on the right side and unloaded the other to match.. Rim looke dfine.. considering i had tubes though.. not saying much.. except that my tire I took off looked like it had been on for 30-40 years.. /forums/images/graemlins/grin.gif
Soundguy
   / Tire Ballast--again. Sorry. #54
Soundguy
   / Tire Ballast--again. Sorry. #55
Wally Worlds winter blend WW fluid is .99 a gallon...$94.00 to fill your tires.
If you have a pull behind 12v sprayer you can use it to fill your tires, there should be a "Y" fitting ( mine does) and just attach a garden hose with your adapter to it and every little bit just relieve the pressure.
   / Tire Ballast--again. Sorry. #56
   / Tire Ballast--again. Sorry. #57
You can cut the 94$ down too.. it doesn't have to be straight washer fluid.. just a mix...
Soundguy
   / Tire Ballast--again. Sorry. #58
Soundguy
   / Tire Ballast--again. Sorry. #59
I am having two new tires installed on my old JD "B" next week and I was told it would cost me $97 for a drum of washer fluid.
Only after reviewing the firestone chart I am second guessing my local tire dealer since according to the chart each 12.4 - 38 tire will take 46 gallon so that means 2 drums. And after reading this topic get me thinking that $97 for 50 gallon is expensive, guess a call is in order Monday morning.
   / Tire Ballast--again. Sorry. #60
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A55788)
2018 Nissan Titan...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2018 Bobcat E26 Mini Excavator (A55787)
2018 Bobcat E26...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
