Tire broke? Front tire bubble bx220
   / Tire broke? Front tire bubble bx220 #1
wjmst
Strongstown, PA
kubota bx2200
Hello,
I was moving rock today (fel) and I noticed that my front tire was misshaped. It has a "bubble" in it and is very soft around that bubble, not rigid like the rest of the tire. The tire is the turf OTR Grassmaster for the bx2200.
Any ideas what could have caused this?
Can it be fixed or do I need to replace the tire?
Can I continue to use the tractor until I get a replacement tire?
It almost looks like a belt broke in the tire, do these tires have belts in them?
Please help.
Thanks
Wes
   / Tire broke? Front tire bubble bx220 #2
I would get a new tire.
Maybe it could be foam filled??
I would use it (but be careful) until your new tire comes in.
   / Tire broke? Front tire bubble bx220 #3
It sounds like the tire has a manufacturing defect and someone should replace it for free. The tire construction is included on the sidewall.
   / Tire broke? Front tire bubble bx220 #4
That is a broke belt in the fabric of the tire. Some might call this a manufacturing defect, but it most likely is a result of blunt force trauma to the tire..... i.e. ....... hitting a sharp object such as a curb, rock, etc. I would get a new tire immediately or have both front tires foam filled. It is only a matter of time before the bubble bursts and if you are doing work, the best that can happen, is you will be stopped for a while... the worse that can happen is anyones guess.... depends on what you are doing when if finally gives up the ghost and goes to tire heaven... /forums/images/graemlins/grin.gif
   / Tire broke? Front tire bubble bx220 #5
Just keep it off the freeway and speeds below 35 mph only /forums/images/graemlins/grin.gif Locate a replacement and work till it won't. Then replace it, JMO
Thanks for the information. I called around to several local Kubota dealers and they all said the same thing. "We can order it, but it will take a few days. If you need a tire today, go to your local tire shop."
So I called around to the local tire shop and they didn't have them in stock. I did call Wal*Mart and they said they had a few tires that size in stock, but I haven't had a chance to check them out yet. After I look at Wal*Mart's tire, then I will make a decision as to what I shall purchase. I have heard that you should keep the tires the same size and tread design, is this true? Obviously, the size is important, but what about tread design. Will I have to buy two tires if I get a different brand?
I also called OTR (the mfg of the tire). They said the tire was out of warrenty, but my local Kubota dealer could order a new one. I said, but I need a tire now! He actually said to go to a local tire shop as well!
The bubble tire is still working for now. BTW: I had a 36x36 cement foundation jack hammered and now I am removing it with the bx. What an amazing job it has done.
Wes
   / Tire broke? Front tire bubble bx220 #7
Tread design isn't that important on a small tractor, like it would be on your car. As long as it is the same size and type.... ie. turf or bar, it won't matter if it is another brand or tread design. If you decide that you need two new tires, then order them from "whole goods department" of Kubota through your tractor dealer. It is less expensive that way.
   / Tire broke? Front tire bubble bx220 #8
</font><font color="blue" class="small">( Thanks for the information. I called around to several local Kubota dealers and they all said the same thing. "We can order it, but it will take a few days. If you need a tire today, go to your local tire shop."
<font color="purple"> I have heard that you should keep the tires the same size and tread design,
is this true? Obviously, ***the size is important, but what about tread design. </font>
Wes
)</font>
*** <font color="purple"> I Have 4 different brands of tires with 4 different tread designs on my Dodge D 50 pick up however all 4 tires are the same size. </font>
Been doing it for 14 years with no problems.
But don't let that fool you experence don't matter .
Been there done that but it don't count.
   / Tire broke? Front tire bubble bx220 #9
All of the tires are the same size huh?????
If you check the engineering specs for all of those different tires i bet you will not find 2 that are actually the same size.
Different models of the same size and manufacturer frequently have different outside diameters.
Never mind 4 different treads and 4 different constructions, sounds like some interesting handling.
   / Tire broke? Front tire bubble bx220 #10
This defies logic and reason..... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif This is like playing Russian Roulette with 6 bullets chambered.... /forums/images/graemlins/crazy.gif
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
Loader Arm (A51691)
Loader Arm (A51691)
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
