Tire Chain Tensioners
   / Tire Chain Tensioners #2
Bungees are cheaper, work just as well and probably easier to install.
I do suggest wearing safety glasses when handling bungees. I still have the scar on my arm when one let go.
   / Tire Chain Tensioners #3
I say they are-but you don't have to spend a lot of $$. I use 3 rubber bungee cords on each wheel- gives you 6 attachment points and adequately eliminates any slack.
   / Tire Chain Tensioners #4
I just get the chain tight and don't use them.
   / Tire Chain Tensioners #5
I bought these for $44.99 a pair. These are well made and very heavy duty. I used a nylon ratchet strap hooked to the top of the tire chain and center ring to tension the springs. I like 'em. tirechains
   / Tire Chain Tensioners #6
I have the same ones from tirechains on my L4400 and really like them.
   / Tire Chain Tensioners #7
Are they worth the investment ?
Not needed if the chains are cut to fit the tires for the correct cross chain length and the correct side chain length.
If either is the wrong length, then tensioners are likely needed.
I prefer having the chains fit and tensioners not needed. :)
   / Tire Chain Tensioners #8
I agree with beenthere 100%. It's better to have the tensioners and not need them than to not have the tensioners and need them. Getting stuff like snow chains and tensioners this time of year can be almost impossible.
   / Tire Chain Tensioners #9
I tried them one time but they didn't hold up. Those 6" black rubbers with the 2 'S' hooks work the best for us. They're on the same shelf as the tarps as TSC.
   / Tire Chain Tensioners #10
I looked and your hooks are pointing in, you might want to turn them out as they could chew a nasty tear in the tire. Hope you do not mind the suggestion.
Craig Clayton
2013 PETERBILT 367 DAYCAB (A47001)
2013 PETERBILT 367...
John Deere 4100 Hood (A47809)
John Deere 4100...
2005 Nissan Pathfinder SUV (A46684)
2005 Nissan...
2013 FONTAINE 53FT STEPDECK W/HORIZONTAL SEPERATOR (A47001)
2013 FONTAINE 53FT...
2025 Swict 78in Bucket Skid Steer Attachment (A46683)
2025 Swict 78in...
12-16.5 SKS1 Tires (A47809)
12-16.5 SKS1 Tires...
