Tire chains on lawn and garden tractor???
   / Tire chains on lawn and garden tractor??? #11
i think you are bes to add weight first, as chains wil tear up the yard, especially if they start to slip.
   / Tire chains on lawn and garden tractor??? #12
I used to keep one rear tire chain on my MTD 800 series garden tracto all the time. the way my yard was layed out I only ever spun one tire so I just decided to keep on the one chain. It never tore up the grass that I can remember.
   / Tire chains on lawn and garden tractor??? #13
My 12 year old Cub Cadet has never had the rear tire chains removed. I couldn't imagine getting around my yard without them! Then again it also has 75# wheel weights and foam filled tires to improve traction in addition to the chains.
   / Tire chains on lawn and garden tractor??? #14
go down to NAPA, or your local auto parts store. for 10 bucks or so you can get the little valve for filling your tires with w/w fluid. this should fix your slipping problem, if it dont then add the chains. that should cure the problem.. /forums/images/graemlins/grin.gif
   / Tire chains on lawn and garden tractor??? #16
I just put a set of tire chains on as the ground here is very wet. Do you think its a good idea to keep the weight off the tires when the machine is not in use by jacking the tractor up?
Thanx for all the help.I`ll fill the tires before the next mowing and give that a try first.
osymandius,, do not know for sure but, seems the weight on the chains all the time should`nt hurt the tires.
   / Tire chains on lawn and garden tractor??? #18
My 1966 Bolins has been setting on the chains for over 30 years and they haven't hurt the tires.
They are the original tires that came on the tractor in 1966
Unused Delta Crash...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2017 Harley Davidson Electra Glide (A52377)
2017 Harley...
2008 Saturn VUE XE SUV (A53117)
2008 Saturn VUE XE...
