Tire chains on lawn and garden tractor???
   / Tire chains on lawn and garden tractor??? #11
i think you are bes to add weight first, as chains wil tear up the yard, especially if they start to slip.
   / Tire chains on lawn and garden tractor??? #12
I used to keep one rear tire chain on my MTD 800 series garden tracto all the time. the way my yard was layed out I only ever spun one tire so I just decided to keep on the one chain. It never tore up the grass that I can remember.
   / Tire chains on lawn and garden tractor??? #13
My 12 year old Cub Cadet has never had the rear tire chains removed. I couldn't imagine getting around my yard without them! Then again it also has 75# wheel weights and foam filled tires to improve traction in addition to the chains.
   / Tire chains on lawn and garden tractor??? #14
go down to NAPA, or your local auto parts store. for 10 bucks or so you can get the little valve for filling your tires with w/w fluid. this should fix your slipping problem, if it dont then add the chains. that should cure the problem.. /forums/images/graemlins/grin.gif
   / Tire chains on lawn and garden tractor??? #16
I just put a set of tire chains on as the ground here is very wet. Do you think its a good idea to keep the weight off the tires when the machine is not in use by jacking the tractor up?
Thanx for all the help.I`ll fill the tires before the next mowing and give that a try first.
osymandius,, do not know for sure but, seems the weight on the chains all the time should`nt hurt the tires.
   / Tire chains on lawn and garden tractor??? #18
My 1966 Bolins has been setting on the chains for over 30 years and they haven't hurt the tires.
They are the original tires that came on the tractor in 1966
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
