ultrarunner
Epic Contributor
- Joined
- Apr 6, 2004
- Messages
- 28,645
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
I believe they kept rotating the tire to get the foam to fill in around the tire consistently otherwise it would be heavy on one side.
There are other wiser guys on here that might be able to tell you more about the process or try to talk you into fluid of some flavor to fill the tires...
I watched as I had my rear Kubota Tires Foamed filled.
The tech drilled a small hole opposite the air stem and pump the hot foam into my tire while it as laying on it's side until it came out the vent hole on the other side.
They also branded the tire with a hot iron that said Foamed Filled.
Since the tires were done while I waited, they carefully used a forklift to load my tires flat in my truck on top of a piece of plywood I had.
The only caution was to wait 24 hours before mounting to make sure the foam had sufficient time to cure "Round"
