tire pressure with filled tires?
   / tire pressure with filled tires? #11
I think you should either REFILL the other tire or take the fluid out of the other front.
Frank, what is the advantage in doing that?
   / tire pressure with filled tires? #13
As it is your tractor is unbalanced. You don't want one corner weighing more than the others. Makes it more prone to tipping.
   / tire pressure with filled tires? #14
Yup. load up the other front or get rid of the fill. You want all tires balanced.
Loading the fronts is fine as long as they are balanced. Don't overfill - you want the weight low (at or below axle level). Remeber that liquids will splash inside the tires and can actually raise your center of gravity. Fill the remainder with air to the same pressure as you normally would. If you don't need air, you probably have too much fill in there.
Foam filled is best, but most expensive. No more flats is an added bonus. Do this when your tires are new - it isn't worth it on older tires.
   / tire pressure with filled tires? #15
Hmmm, I would think doing it to older tires would allow you to get a lot more use out of them, I'm thinking of weather checked, not worn out ones......
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
John Deere Disk Chisel (A50515)
John Deere Disk...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A52128)
2018 Ram 5500...
2015 CASE 850M WT CRAWLER DOZER (A51242)
2015 CASE 850M WT...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
