Tire Pressure
/ Tire Pressure #1
lewbest
near Waco, TX
Hey guys
This may be a little OT but I'm hoping someone knows the answer.
I have a small Ditch Witch; has 33-8.5x12 (I think that's the correct order; didn't write it down) :( tires that are showing 10 psi when I check them. It's been sitting a coupla years since last use & I need to use it next week; I'd like to have the proper pressure in the tires (naturally)
Thanks!
Lew near Waco, TX
/ Tire Pressure #2
10-15 psi should be fine, and if the seem to be too soft, add a bit more. The sidewall should state a max pressure.
/ Tire Pressure
Thanks; I thought the pressure should be on the sidewall but I can't find it. These are regular "farm tractor type" tread (like V shapes) so I should be looking at different sides of the tires viewing right or left (IOW shouldn't be "hidden" on the back side).
Thanks again!
Lew
/ Tire Pressure #4
Lew,
Most ag treads on compact machines like to have 10-15 PSI as stated by beenthere - if overinflated they will not work as intended.
If the sidewall crumples when driving add air until you have the bar treads on the edge are touching a solid surface.
/ Tire Pressure
Thanks Carl; sounds good. These tires look pretty rotten but since i VERY seldom use it I don't want to over-inflate them; might "pop."
Lew
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2008 Nissan Xterra SUV (A64557)
2008 Nissan Xterra...
1999 INTERNATIONAL 4700 - 6 WHEEL GRAIN TRUCK (A64278)
1999 INTERNATIONAL...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 44,125 (A64557)
Year: 2023 Make...
