Tire repair
/ Tire repair #1
Mike_Kanzer
Chester county, PA
Kubota L3830 HST, JD Gator 855D
I was wondering how well the tire plug kits work on large rear fluid filled tractor tires? I have a Kubota L3830 and have put slime in the front tires which have handled a small puncture. Do the plugs they sell really seal up small leaks? Thanks - any coments from those who have used them would be appreciated - Mike
/ Tire repair #2
Plugs work really well, I use them quite regularly and SWMBO probably even uses them more then I. They can complemnent slime quite well also.
That said, when you said large FLUID FILLED rear tires, I am assuming you are speaking of ballasted tires, and the ballasts I can think of off hand, CC or Antifreeze or WW fluid, would prevent the plugs I use from working.
Large tractor tubeless tractor tire with just air, there are probably 4 or 5 plugs in each of the rear tires of our tractor.
/ Tire repair #3
Mike I have used a simple plug kit once on a antifreeze filled rear tire. I know it held for like 2 or 3 years.
/ Tire repair #4
Mike, turn the tire so the leak is at the top with the air space. Then use a plug as you would on a normally air filled tire. It should hold up fine.
Sincerely Dirt
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
MULCHER (A58214)
MULCHER (A58214)
Hilti TE 2000-AVR Electric Jack Hammer (A60352)
Hilti TE 2000-AVR...
2020 DRAGON ESP...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
