Brown Dog
Veteran Member
- Joined
- Jun 5, 2014
- Messages
- 1,480
- Location
- North GA
- Tractor
- John Deere 5115M 5101E H260 5115M 540M all MFD
I May have missed it but sounds like your rear 16.9-30’s aren’t fluid filled.
IF so : you need to fill them with antifreeze mix, beet juice or something besides calcium that won’t freeze in Northern MI
Those 16.9 is All you need.
You can add weights AND fluid filled to rears & you won’t have any problem whatsoever in snow, mud OR unweighting the rear with 2 round bales of hay up front.
You can also add a 3ph hay spear out back & carry a round bale for even more rear weight.
All 3 sources of weight out back would be superb with the narrower 16.9’s
Any tractor can’t be used to its potential IF not fluid filled AND wheel weights too imo.
I have all 3 of my JD & couldn’t be happier
All that weight also rides way better on rough ground too so it’s a Win Win in my book.
IF you have hills to pull : you DEFINITELY loose power & will have to run 1 gear lower than normal.
JD transmissions are really tall geared with those TALL R1 tires.
