Tires for SUV - P or LT?
   / Tires for SUV - P or LT? #21
Bridgestone's Mr. Tenuta says "no."
"The tire is an integral part of the vehicle's chassis, suspension and braking systems," he says. "The OE tire is specifically selected as part of these systems."
Campbell Ford's Mr. Egan agrees: "We see this (using passenger tires on trucks rated for light truck) a lot. If this vehicle was going through a commercial safety inspection with the P-metric tires, it would fail."
It's true, however, that not everyone will subject their vehicle to severe load carrying or heavy towing. But it's also true that trucks are easier to overload than cars, and for those who've purchased big, diesel-engined vehicles like Mr. Rizzuti's F350 Super Duty, they likely have serious hauling applications in mind. In Mr. Rizzuti's case, this includes towing a 7,000 lb trailer, plus carrying luggage, and passengers for which he requires the LT-metric tires.
After mounting the correct tires on his truck (in this case Firestone Transforce) Mr. Rizzuti conceded that the ride is firmer. "But it tracks and turns so much easier. There's a real difference in handling," he says. "I'd never attempt pulling our trailer without the LT-metric tires," he added.
How do you know if your truck should be using LT-metric tires? A placard in the doorjamb, and the owner's manual will tell you. Some vehicles also have this information on a plate inside the glove box, or on the inside of the fuel filler door.
Or go to Bridgestone Tires | Car Tires, Light Truck Tires, Run Flat Tires, and click on Tire Fitment. The table lists all the trucks by make, model and year, and their recommended tires
For further information on this subject, check TireSafety.com.
Understanding tire size:
Example: LT256/75R16E
LT Light Truck
265 Width in millimetres of the tire
75 Height, or aspect ratio of the tire, measured as a percentage of width (in this case, 75%)
R Radial tire
16 Width (diameter) in inches of the wheel
E the load rating of this LT tire
I found the part about the DOT inspection very relevant
   / Tires for SUV - P or LT? #22
After 2 sets of p's ,OEM goodyear somethings (40K miles), Kuhmo ecsta (35K Miles) went with michelin LTX M/S's on the wife's 2006 Highlander. 45K and still look good and perform well. They handle better and have decent traction and ride. Overall much happier with the LT tire even for the added price.
Look at the size on your sidewall. If it starts with a P they are not LT tires. LTX is just the model name. They are probably the best tires you can buy for an SUV though.
edit - they have many smaller sizes that are LT so maybe I dont know what I'm talking about!
   / Tires for SUV - P or LT? #23
To the original poster - if its a small SUV you probably cant even buy real LT tires for it. They are not available in many sizes. There is also absolutely no need for LT tires on a average SUV. If you have a Suburban towing a 8k boat fine but for everything else it is overkill.
   / Tires for SUV - P or LT? #24
My '96 2 door Tahoe came with LT's, my 4 door '96 Tahoe came with P-metrics. The 2 door came with rear leaf springs, the 4 door coils. GM said that either could use either so long as size range, load range minimums, and tire pressures were maintained. The 2 door used 75 series in either 245/75- or 265/75/16's. The 4 door used the same width but in a 70 series. This was also true of the K- Blazers of the era. They used 15's in 235 70-75 on 4wd. ;)
My Xterra came with 265/75/16 on it, which is the same size my dodge/Cummins used..
I have the Pro-4x model - the other two Xterra models use a different tire size and there are no LT tires available for it..
b
Why would you want to use a stiffer tire for a "4x4 small/mid size SUV" and give up any comfort you may have unless you haul alot of weight or do some serious offroading ???? :confused:
That is my original question - I was looking for input on why someone would want to go the LT route..
b
   / Tires for SUV - P or LT? #27
Sooo..I went out and looked and you are correct. They ARE P's! It's me that doesn't know what I'm talking about:ashamed:
To the OP: Sorry, I guess I have nothing for you.
   / Tires for SUV - P or LT? #28
If you tow over 5000 lbs much or you go off road even in deep sNd where sidewall killers can hide, I would run lt's. AbsOlutely no reason they can't be used on a real suv.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
2014 Ford F-150 Ext. Cab Pickup Truck (A51692)
2014 Ford F-150...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
