Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,316
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
newbury said:We've had this discussion a number of times. I needed a multipurpose truck, I can't yet afford one for every use. I wanted the dually for stability and payload capacity in a Crew Cab, 4x4, configuration. Per spec my "rated" payload capacity is about 1,000 lbs more than the same truck in SRW.
Just the little load of pallet rack I picked up, with what I had in the cab, approached the rated payload capacity of the SRW configuration.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=285552"/>
It may be called a 1 ton but it's rated at about 4,240 lbs payload capacity.
The reason I want the lift is ground clearance, not looks.
Thanks for the pointers the on the tires and on 5th wheels - I don't have a 5th wheel YET so had not thought about that aspect.
My 06 F350 SRW has a max gvwr of 11,500# and weighs 7,600# with fuel, my junk, and me in it. That leaves a honest 3,900# or two tons of payload capacity.
You just have to know how to order them.
Chris
