FMFProperties
Bronze Member
Just an FYI, I got bucket and dipperstick forces for the BK215 from Titan. (They sent me the manual) Bucket force 2592lbs, dipperstick force 1975lbs. Lowest of the hoes I have data on. (Titan, are you listening? The BH looks structurally sound, get the supplier to use slightly larger cylinders and get these numbers up!)
I have a spreadsheet of backhoe choices, and the BK215 is actually a couple hundred pounds lower for both forces than the FHM backhoe, commonly available on Ebay. I suppose the dipperstick numbers don't vary by a whole lot, but bucket forces range quite a bit.
(Click the tiny image below to see it bigger)
Also worth noting that the Branson backhoe is made by Ansung, and very likely just painted different. Branson must be using slightly more pressure to it, or measuring differently. I included it because that's the hoe I could get locally...
It appears to me that bang for the buck, Woodmaxx is probably a good choice. Their price does include the pump and tank, so if they come out with a version that runs off the tractor, it should be cheaper...
Thank you !! Very informative. I'm currently looking for people's experience with these type of backhoes and hopefully more actual users will come out of the woodwork with opinions.
