Titan Trac-Loader Tires 10-16.5 NHS HELP
   / Titan Trac-Loader Tires 10-16.5 NHS HELP #1
twodaughters
Mansfield, GA
New Holland TC 35D
Brother. I have one front tire on my New Holland tc35d that keeps going flat. I think I am going to have to replace it but don't know where to start. I would like to get a used tire so it matches w/the rest of them but I may have to go w/a new one.
Does anyone have a suggestion on where I would find this tire? Do I have to get the exact same tire/brand that is on it now? This will be my first tractor tire exchange so I'm a bit lost. I did google it and got a one or two suggestions but most of the links took me to auto tires despite my specific tire info.
I've seen inner tubes offered for this size tire. Could I use that? It sure would be a lot cheaper. I have some dry rot around the tire and I think the air is leaking there, although the tire fixer did find a screw in it. Has anyone tried the inner tube?
Thanks for any help you might offer.
   / Titan Trac-Loader Tires 10-16.5 NHS HELP #2
tire shop should be able to fix the one you have
   / Titan Trac-Loader Tires 10-16.5 NHS HELP #3
I've used fix a flat with success before but if that had not worked I'd have put a tube in it. I think you'd have to check with a tractor tire dealer to find a used tire in your size. Maybe you could send Millertire (a member) a PM to see what he has lying around.
Hey Whis, I have had 2 patches and about 4 plugs put in it. I think it's had it but thanks for the advice.
Hey George2615, thank you also for pointing me toward Millertire. I'll see if I can reach him through the members list.
Well, I looked in the members list and couldn't find Millertire. Does he have another name or could you pls tell me how to find him? I'm assuming the him part.
thanks,
Thanks so much George.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
MILWAUKEE & DEWALT SAWZALL (A58374)
MILWAUKEE & DEWALT...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
