TN 1 yard bucket on a tc55D? thoughts?
   / TN 1 yard bucket on a tc55D? thoughts? #1
Roto
Mid Maine
TC55DA and TC33D
I dont like my bucket that comes with my TC55DA. It is a half-yard bucket and too small for anything but doing dirt/gravel work. It is good for that but most of the time I use my bucket for shavings, manure, leaves, hay, snow etc...
Now my old tractor has a one yard bucket that i use all the time because it hold so much more and does a much better job backdragging and is 7 feet wide rather then 6 feet. That old tractor has same lift capacity of about a ton. I never had a problem. What i would like to do is buy another bucket which is a one yard bucket and about 7 feet wide with QA. I think the TN bucket is a 7 foot one and a one yard and that would work great QA on and off and i can change buckets quickly. Anyone know if the TN bucket is indeed 7 foot and one yard? Any other thoughts on my idea?
Mike
   / TN 1 yard bucket on a tc55D? thoughts? #2
Check out the NH website under loaders then specs at the top of the page i didnt know they had so many choices for the tn.
   / TN 1 yard bucket on a tc55D? thoughts? #3
My TN bucket is 6' wide and probably 2/3, 3/4 of a yard. (it can fill up alot)
But i think you can get a 1000 different buckets.
   / TN 1 yard bucket on a tc55D? thoughts? #4
Check out ATIs 600 series high capacity buckets but keep in mind a bucket this large will weigh ~600 lbs
My buddy has a TN 65 and looks to be a 7 foot bucket and about one yard. NH has a bunch of loaders but not as many buckets. the TC series only has like 3 buckets for several models. Lots of loaders but few buckets.
Mike
   / TN 1 yard bucket on a tc55D? thoughts? #6
well, mine is a standard quick attach, you could put any bucket that is that standard quick attach.
skid steer, forks, anything.
That's quite a bit more choices.
   / TN 1 yard bucket on a tc55D? thoughts? #7
Big aluminum QA bucket would be nice. aluminum is around 1/3 the weight of steel so when it was done with extra stiffeners it would probably be 1/2 the weight. Titanium would be super Same weight as Aluminum, same strength as steal but the cost would be out of site . Maybe a wood box for the forks. Puts the load fouther out though. Some one posted an aluminum box for forks not long a go with pictures.
2002 TRAVIS BODY & TRAILER, INC. 48 END DUMP TRAILER (A58214)
2002 TRAVIS BODY &...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2244 (A58376)
2244 (A58376)
2013 Hyundai Veloster Hatchback (A56859)
2013 Hyundai...
2013 John Deere 5075E (A57148)
2013 John Deere...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
