redneckford
Platinum Member
Are they really burning more gallons of fuel are do we need to double check the volume measurements that we are using. (Faulty Fuel Pump Measurements at fueling stations is what i was referring to) I know you have a hard time understanding my jiberis but kind'ove like a glass of water and ice--one volume---and then run it into a blender--gas pump--- and you get more volume but no more water or ice just more air mixed in. (After it has time to settle-in your 55 gallon drum---back to the same volume measurements--45gallons--however the pump measured 55 gallons of material passing thru) You pay for 55 gallons of fuel but only have 45 gallons. Hard for me to understand how the dried out fuel, sulfur removed, is taking more "gallons" to run the same engine at the same rpm if the diesel fuel is "spraying" into the cylinder correctly and the external temperature is the same. Sorry just worked on alot of 3 and 4 cylinder Fords in the last 30 years and think something else is going on here. Drier Fuel May be causing the injectors or pump to mis apply fuel due to the dry content. (We may need to recalibrate older injection pumps and injectors)Maybe more unburnt fuel discharge? But I thought that the dried out fuel was suppose to cause less pollution not more. More fuel to do the same amount of work sounds like more pollution to me not less. Many of the old fuel station pumps can only work if the price per gallon is less than $4.00 per gallon!! I could get into the molecular structure of high sulfur diesel and low sulfur diesel but i think that would diffently get my post censored!!!
