TN70A 4WD working?
   / TN70A 4WD working? #11
so how does the tractor know that the rear wheels are slipping?
theres some sort of diffrential clutch between the front wheels (which wouldnt be moveing) and the rears which are?
   / TN70A 4WD working? #12
I don't believe that's how it works. When you engage 4WD, the drive shaft to the front differential turns (without any regard as to rear wheel slippage). Since the front wheels are driven through a differential, they both only get power until one slips and then the one that is slipping gets all the powerunless you have a limited slip front differential. On my 2120 when I overload the bucket, I can get the tractor up on one front wheel (carefully) and still back up with 3 wheels off the ground. On my TN, when I engage the electro hydro differential lock, it locks both axles, hence true 4WD. And yes, it is tuff to steer.
Andy
Andy
My TN70A (8x8 with power shuttle) does not have the elctro hydro diff. My only diff lock is my rear wheels with the heel peddle. Your setup spounds nice.
Bob
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
CAT 312C EXCAVATOR (A58216)
CAT 312C EXCAVATOR...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
